Results 19 to 24 of 35
Thread: Windows 10 RS6 1903 Updated Class Maps and Import script for Light Mode
    Mr GRiM is offline
    Administrator
    5,328
    837 Thread(s)
    Star Windows 10 RS6 1903 Updated Class Maps and Import script for Light Mode
    OK I know Nicely already posted one of these but I have made a new one, Light Mode import script tested and working 100% with all themes.
    This update also contains the separate Dark Mode update script, I have also tested the updated theme on 1809 and they work fine, the only thing you need to change is the shellstyle.dll for Old New Explorer compatibility.
    Hold shift and click on Import Stylehack and then select "Light Mode Import Script" then Apply Script.
    Now reopen the saved theme so all the new classes show correctly in the new Windows 10 Light Mode section.
    All the Light Mode classes have been put in their own section with the same layout as the default theme.
    Here is what's in the import script for anyone interested.
    Code:
    	Author:	Mr GRiM
    <stylescript>
    	<add>
    		<class name="FileExplorerBannerContainer"/>
    		<class name="DarkMode::FileExplorerBannerContainer"/>
    		<class name="LightMode_ImmersiveStart::Menu"/>
    		<class name="TaskBarLight::Rebar"/>
    		<class name="TaskBarSmallIconsLight::Rebar"/>
    		<class name="TaskBarLight::Toolbar"/>
    		<class name="TaskBarVertLight::Toolbar"/>
    		<class name="TaskBandExtendedUILight::TaskBandExtendedUI"/>
    		<class name="TaskBand2CompositedLight::TaskBand2"/>
    		<class name="TaskBand2CompositedSmallIconsLight::TaskBand2"/>
    		<class name="TaskBand2CompositedVertical8Light::TaskBand2"/>
    		<class name="TaskBand2CompositedSmallIconsVertical8Light::TaskBand2"/>
    		<class name="TaskBand2Light::TaskBand2"/>
    		<class name="TaskBand2VerticalLight::TaskBand2"/>
    		<class name="TaskBand2SmallIconsLight::TaskBand2"/>
    		<class name="TaskBand2SmallIconsVerticalLight::TaskBand2"/>
    	</add>
    	<copy>
    	<!-- Windows 10 Dark Mode > Taskbar & System Tray -->
    		<properties sourceClass="TaskBar::Rebar" sourcePart="0" sourceState="0" destClass="TaskBarLight::Rebar" destPart="0" destState="0"/>
    		<properties sourceClass="TaskBar::Rebar" sourcePart="1" sourceState="0" destClass="TaskBarLight::Rebar" destPart="1" destState="0"/>
    		<properties sourceClass="TaskBar::Rebar" sourcePart="2" sourceState="0" destClass="TaskBarLight::Rebar" destPart="2" destState="0"/>
    		<properties sourceClass="TaskBar::Rebar" sourcePart="4" sourceState="0" destClass="TaskBarLight::Rebar" destPart="4" destState="0"/>
    		<properties sourceClass="TaskBar::Rebar" sourcePart="5" sourceState="0" destClass="TaskBarLight::Rebar" destPart="5" destState="0"/>
    		<properties sourceClass="TaskBarSmallIcons::Rebar" sourcePart="0" sourceState="0" destClass="TaskBarSmallIconsLight::Rebar" destPart="0" destState="0"/>
    		<properties sourceClass="TaskBarSmallIcons::Rebar" sourcePart="1" sourceState="0" destClass="TaskBarSmallIconsLight::Rebar" destPart="1" destState="0"/>
    		<properties sourceClass="TaskBarSmallIcons::Rebar" sourcePart="2" sourceState="0" destClass="TaskBarSmallIconsLight::Rebar" destPart="2" destState="0"/>
    		<properties sourceClass="TaskBarSmallIcons::Rebar" sourcePart="4" sourceState="0" destClass="TaskBarSmallIconsLight::Rebar" destPart="4" destState="0"/>
    		<properties sourceClass="TaskBarSmallIcons::Rebar" sourcePart="5" sourceState="0" destClass="TaskBarSmallIconsLight::Rebar" destPart="5" destState="0"/>
    		<properties sourceClass="TaskBar::Toolbar" sourcePart="0" sourceState="0" destClass="TaskBarLight::Toolbar" destPart="0" destState="0"/>
    		<properties sourceClass="TaskBar::Toolbar" sourcePart="1" sourceState="0" destClass="TaskBarLight::Toolbar" destPart="1" destState="0"/>
    		<properties sourceClass="TaskBar::Toolbar" sourcePart="2" sourceState="0" destClass="TaskBarLight::Toolbar" destPart="2" destState="0"/>
    		<properties sourceClass="TaskBarVert::Toolbar" sourcePart="0" sourceState="0" destClass="TaskBarVertLight::Toolbar" destPart="0" destState="0"/>
    		<properties sourceClass="TaskBarVert::Toolbar" sourcePart="1" sourceState="0" destClass="TaskBarVertLight::Toolbar" destPart="1" destState="0"/>
    		<properties sourceClass="TaskBarVert::Toolbar" sourcePart="2" sourceState="0" destClass="TaskBarVertLight::Toolbar" destPart="2" destState="0"/>
    		<properties sourceClass="TaskBand2" sourcePart="0" sourceState="0" destClass="TaskBand2Light::TaskBand2" destPart="0" destState="0"/>
    		<properties sourceClass="TaskBand2Composited::TaskBand2" sourcePart="0" sourceState="0" destClass="TaskBand2Light::TaskBand2" destPart="0" destState="0"/>
    		<properties sourceClass="TaskBand2Light::TaskBand2" sourcePart="0" sourceState="0" destClass="TaskBand2CompositedLight::TaskBand2" destPart="0" destState="0"/>
    		<properties sourceClass="TaskBand2Composited::TaskBand2" sourcePart="0" sourceState="0" destClass="TaskBand2CompositedLight::TaskBand2" destPart="0" destState="0"/>
    		<properties sourceClass="TaskBand2Composited::TaskBand2" sourcePart="1" sourceState="0" destClass="TaskBand2CompositedLight::TaskBand2" destPart="1" destState="0"/>
    		<properties sourceClass="TaskBand2Composited::TaskBand2" sourcePart="2" sourceState="0" destClass="TaskBand2CompositedLight::TaskBand2" destPart="2" destState="0"/>
    		<properties sourceClass="TaskBand2Composited::TaskBand2" sourcePart="3" sourceState="0" destClass="TaskBand2CompositedLight::TaskBand2" destPart="3" destState="0"/>
    		<properties sourceClass="TaskBand2Composited::TaskBand2" sourcePart="4" sourceState="0" destClass="TaskBand2CompositedLight::TaskBand2" destPart="4" destState="0"/>
    		<properties sourceClass="TaskBand2" sourcePart="5" sourceState="0" destClass="TaskBand2CompositedLight::TaskBand2" destPart="5" destState="0"/>
    		<properties sourceClass="TaskBand2Light::TaskBand2" sourcePart="0" sourceState="0" destClass="TaskBand2CompositedSmallIconsLight::TaskBand2" destPart="0" destState="0"/>
    		<properties sourceClass="TaskBand2CompositedSmallIcons::TaskBand2" sourcePart="0" sourceState="0" destClass="TaskBand2CompositedSmallIconsLight::TaskBand2" destPart="0" destState="0"/>
    		<properties sourceClass="TaskBand2CompositedSmallIcons::TaskBand2" sourcePart="1" sourceState="0" destClass="TaskBand2CompositedSmallIconsLight::TaskBand2" destPart="1" destState="0"/>
    		<properties sourceClass="TaskBand2CompositedSmallIcons::TaskBand2" sourcePart="2" sourceState="0" destClass="TaskBand2CompositedSmallIconsLight::TaskBand2" destPart="2" destState="0"/>
    		<properties sourceClass="TaskBand2CompositedSmallIcons::TaskBand2" sourcePart="3" sourceState="0" destClass="TaskBand2CompositedSmallIconsLight::TaskBand2" destPart="3" destState="0"/>
    		<properties sourceClass="TaskBand2CompositedSmallIcons::TaskBand2" sourcePart="4" sourceState="0" destClass="TaskBand2CompositedSmallIconsLight::TaskBand2" destPart="4" destState="0"/>
    		<properties sourceClass="TaskBand2SmallIcons::TaskBand2" sourcePart="5" sourceState="0" destClass="TaskBand2CompositedSmallIconsLight::TaskBand2" destPart="5" destState="0"/>
    		<properties sourceClass="TaskBand2Light::TaskBand2" sourcePart="0" sourceState="0" destClass="TaskBand2CompositedVertical8Light::TaskBand2" destPart="0" destState="0"/>
    		<properties sourceClass="TaskBand2Composited::TaskBand2" sourcePart="3" sourceState="0" destClass="TaskBand2CompositedVertical8Light::TaskBand2" destPart="3" destState="0"/>
    		<properties sourceClass="TaskBand2Composited::TaskBand2" sourcePart="4" sourceState="0" destClass="TaskBand2CompositedVertical8Light::TaskBand2" destPart="4" destState="0"/>
    		<properties sourceClass="TaskBand2CompositedVertical8::TaskBand2" sourcePart="5" sourceState="0" destClass="TaskBand2CompositedVertical8Light::TaskBand2" destPart="5" destState="0"/>
    		<properties sourceClass="TaskBand2Light::TaskBand2" sourcePart="0" sourceState="0" destClass="TaskBand2CompositedSmallIconsVertical8Light::TaskBand2" destPart="0" destState="0"/>
    		<properties sourceClass="TaskBand2CompositedSmallIcons::TaskBand2" sourcePart="3" sourceState="0" destClass="TaskBand2CompositedSmallIconsVertical8Light::TaskBand2" destPart="3" destState="0"/>
    		<properties sourceClass="TaskBand2CompositedSmallIcons::TaskBand2" sourcePart="4" sourceState="0" destClass="TaskBand2CompositedSmallIconsVertical8Light::TaskBand2" destPart="4" destState="0"/>
    		<properties sourceClass="TaskBand2CompositedSmallIconsVertical8::TaskBand2" sourcePart="5" sourceState="0" destClass="TaskBand2CompositedSmallIconsVertical8Light::TaskBand2" destPart="5" destState="0"/>
    		<properties sourceClass="TaskBand2" sourcePart="5" sourceState="0" destClass="TaskBand2Light::TaskBand2" destPart="5" destState="0"/>
    		<properties sourceClass="TaskBand2" sourcePart="6" sourceState="0" destClass="TaskBand2Light::TaskBand2" destPart="6" destState="0"/>
    		<properties sourceClass="TaskBand2" sourcePart="7" sourceState="0" destClass="TaskBand2Light::TaskBand2" destPart="7" destState="0"/>
    		<properties sourceClass="TaskBand2" sourcePart="8" sourceState="0" destClass="TaskBand2Light::TaskBand2" destPart="8" destState="0"/>
    		<properties sourceClass="TaskBand2" sourcePart="9" sourceState="0" destClass="TaskBand2Light::TaskBand2" destPart="9" destState="0"/>
    		<properties sourceClass="TaskBand2" sourcePart="10" sourceState="0" destClass="TaskBand2Light::TaskBand2" destPart="10" destState="0"/>
    		<properties sourceClass="TaskBand2" sourcePart="11" sourceState="0" destClass="TaskBand2Light::TaskBand2" destPart="11" destState="0"/>
    		<properties sourceClass="TaskBand2" sourcePart="12" sourceState="0" destClass="TaskBand2Light::TaskBand2" destPart="12" destState="0"/>
    		<properties sourceClass="TaskBand2" sourcePart="13" sourceState="0" destClass="TaskBand2Light::TaskBand2" destPart="13" destState="0"/>
    		<properties sourceClass="TaskBand2" sourcePart="14" sourceState="0" destClass="TaskBand2Light::TaskBand2" destPart="14" destState="0"/>
    		<properties sourceClass="TaskBand2Vertical::TaskBand2" sourcePart="5" sourceState="0" destClass="TaskBand2VerticalLight::TaskBand2" destPart="5" destState="0"/>
    		<properties sourceClass="TaskBand2SmallIcons::TaskBand2" sourcePart="5" sourceState="0" destClass="TaskBand2SmallIconsLight::TaskBand2" destPart="5" destState="0"/>
    		<properties sourceClass="TaskBand2SmallIconsVertical::TaskBand2" sourcePart="5" sourceState="0" destClass="TaskBand2SmallIconsVerticalLight::TaskBand2" destPart="5" destState="0"/>
    	<!-- Windows 10 Dark Mode > Lists, Menus, & Tabs -->
    		<properties sourceClass="ImmersiveStart::Menu" sourcePart="9" sourceState="0" destClass="LightMode_ImmersiveStart::Menu" destPart="9" destState="0"/>
    		<properties sourceClass="ImmersiveStart::Menu" sourcePart="14" sourceState="0" destClass="LightMode_ImmersiveStart::Menu" destPart="14" destState="0"/>
    		<properties sourceClass="ImmersiveStart::Menu" sourcePart="14" sourceState="1" destClass="LightMode_ImmersiveStart::Menu" destPart="14" destState="1"/>
    		<properties sourceClass="ImmersiveStart::Menu" sourcePart="14" sourceState="2" destClass="LightMode_ImmersiveStart::Menu" destPart="14" destState="2"/>
    		<properties sourceClass="ImmersiveStart::Menu" sourcePart="14" sourceState="3" destClass="LightMode_ImmersiveStart::Menu" destPart="14" destState="3"/>
    		<properties sourceClass="ImmersiveStart::Menu" sourcePart="14" sourceState="4" destClass="LightMode_ImmersiveStart::Menu" destPart="14" destState="4"/>
    		<properties sourceClass="ImmersiveStart::Menu" sourcePart="15" sourceState="0" destClass="LightMode_ImmersiveStart::Menu" destPart="15" destState="0"/>
    	</copy>
    	<add>
    	<!-- Windows 10 Dark Mode > Explorer & Shell -->
    		<property class="FileExplorerBannerContainer" part="0" state="0" name="FILLCOLOR:COLOR" value="f4f4f4"/>
    		<property class="FileExplorerBannerContainer" part="0" state="0" name="TEXTCOLOR:COLOR" value="000000"/>
    		<property class="FileExplorerBannerContainer" part="1" state="1" name="FILLCOLOR:COLOR" value="f4f4f4"/>
    		<property class="FileExplorerBannerContainer" part="1" state="1" name="TEXTCOLOR:COLOR" value="000000"/>
    		<property class="FileExplorerBannerContainer" part="1" state="2" name="FILLCOLOR:COLOR" value="f4f4f4"/>
    		<property class="FileExplorerBannerContainer" part="1" state="2" name="TEXTCOLOR:COLOR" value="b3b3b3"/>
    		<property class="DarkMode::FileExplorerBannerContainer" part="0" state="0" name="FILLCOLOR:COLOR" value="333333"/>
    		<property class="DarkMode::FileExplorerBannerContainer" part="0" state="0" name="TEXTCOLOR:COLOR" value="dedede"/>
    		<property class="DarkMode::FileExplorerBannerContainer" part="1" state="1" name="FILLCOLOR:COLOR" value="333333"/>
    		<property class="DarkMode::FileExplorerBannerContainer" part="1" state="1" name="TEXTCOLOR:COLOR" value="ffffff"/>
    		<property class="DarkMode::FileExplorerBannerContainer" part="1" state="2" name="FILLCOLOR:COLOR" value="333333"/>
    		<property class="DarkMode::FileExplorerBannerContainer" part="1" state="2" name="TEXTCOLOR:COLOR" value="6a6a6a"/>
    	<!-- Stupid fix for removing the TaskBar height adjust on my themes -->
    		<property class="TaskBar" part="0" state="0" name="HEIGHT:INT" value="4"/>
    	</add>
    	<remove>
    		<property class="TaskBand2CompositedLight::TaskBand2" part="1" state="0" name="IMAGEFILE:FILENAME"/>
    		<property class="TaskBand2CompositedLight::TaskBand2" part="2" state="0" name="IMAGEFILE:FILENAME"/>
    		<property class="TaskBand2CompositedLight::TaskBand2" part="3" state="0" name="IMAGEFILE:FILENAME"/>
    		<property class="TaskBand2CompositedLight::TaskBand2" part="4" state="0" name="IMAGEFILE:FILENAME"/>
    		<property class="TaskBand2CompositedLight::TaskBand2" part="5" state="0" name="IMAGEFILE:FILENAME"/>
    		<property class="TaskBand2CompositedSmallIconsLight::TaskBand2" part="1" state="0" name="IMAGEFILE:FILENAME"/>
    		<property class="TaskBand2CompositedSmallIconsLight::TaskBand2" part="2" state="0" name="IMAGEFILE:FILENAME"/>
    		<property class="TaskBand2CompositedSmallIconsLight::TaskBand2" part="3" state="0" name="IMAGEFILE:FILENAME"/>
    		<property class="TaskBand2CompositedSmallIconsLight::TaskBand2" part="4" state="0" name="IMAGEFILE:FILENAME"/>
    		<property class="TaskBand2CompositedSmallIconsLight::TaskBand2" part="5" state="0" name="IMAGEFILE:FILENAME"/>
    		<property class="TaskBand2CompositedVertical8Light::TaskBand2" part="3" state="0" name="IMAGEFILE:FILENAME"/>
    		<property class="TaskBand2CompositedVertical8Light::TaskBand2" part="4" state="0" name="IMAGEFILE:FILENAME"/>
    		<property class="TaskBand2CompositedVertical8Light::TaskBand2" part="5" state="0" name="IMAGEFILE:FILENAME"/>
    		<property class="TaskBand2CompositedSmallIconsVertical8Light::TaskBand2" part="3" state="0" name="IMAGEFILE:FILENAME"/>
    		<property class="TaskBand2CompositedSmallIconsVertical8Light::TaskBand2" part="4" state="0" name="IMAGEFILE:FILENAME"/>
    		<property class="TaskBand2CompositedSmallIconsVertical8Light::TaskBand2" part="5" state="0" name="IMAGEFILE:FILENAME"/>
    		<property class="TaskBand2Light::TaskBand2" part="5" state="0" name="IMAGEFILE:FILENAME"/>
    		<property class="TaskBand2Light::TaskBand2" part="6" state="0" name="IMAGEFILE:FILENAME"/>
    		<property class="TaskBand2Light::TaskBand2" part="7" state="0" name="IMAGEFILE:FILENAME"/>
    		<property class="TaskBand2Light::TaskBand2" part="8" state="0" name="IMAGEFILE:FILENAME"/>
    		<property class="TaskBand2SmallIconsLight::TaskBand2" part="5" state="0" name="IMAGEFILE:FILENAME"/>
    		<property class="TaskBand2VerticalLight::TaskBand2" part="5" state="0" name="IMAGEFILE:FILENAME"/>
    		<property class="TaskBand2SmallIconsVerticalLight::TaskBand2" part="5" state="0" name="IMAGEFILE:FILENAME"/>
    		<class class="Taskbar2CompositedLight::TaskBar"/>
    		<class class="ShowDesktopLight::Button"/>
    		<class class="VerticalShowDesktopLight::Button"/>
    	</remove>
    </stylescript>
    Just a disclaimer, I am not responsible for any one trying out these scripts or for anyone who bricks their system, these are experimental and should be used on Virtual machine for safety.
  1. Windows 10 19H1 1903 Updated ClassMaps and Import Scripts
    By Mr GRiM in forum Updates & Style Hacks For WSB
    Last Post: February 13th, 2022, 06:34 PM
  2. Custom Class Maps and Import Scripts for Windows 10 TH2 & RS1
    Last Post: March 14th, 2020, 07:01 AM
  3. Replies: 10
    Last Post: May 5th, 2019, 06:38 PM
  4. Custom Class maps & import scripts for Windows 10 RS1+ Version 1607 - 1703
    Last Post: March 7th, 2018, 06:46 PM
  5. Windows 10 TH2 November Update Class maps and Class Groups for WSB
    Last Post: November 18th, 2015, 06:26 AM
