Results 1 to 6 of 9
Thread: Aero 7 theme for Windows 10 1903
May 28th, 2019 01:20 PM #1
- 5,503
Aero 7
Aero 7 Lite
Aero 7 Clear
Aero 7 Square
for full working you need go to
Personalize/Colors and enable Start,taskbar and action center (on)
May 28th, 2019 01:25 PM #2
- Nov 2017
- Australia
- 1,328
- 11 Thread(s)
This is really Cool Moon, now we can enjoy W7 Aero Themes on W10 1903 Thanks for this mateCheerz !!
May 31st, 2019 01:31 PM #3
- May 2019
- USA
- 1
- 0 Thread(s)
An error was detected in the Aero 7 Theme For Win10 1903 in the form of an artifact: if you run dxdiag, then in the video adapter tab and in the other tabs there will be a black square at the junction of the vertical and horizontal scroll bars. Please correct this error!
June 1st, 2019 03:09 AM #4
- 5,503
sorry for this i can try fix it later because i have more works now
thank you for the info i dont know all issues because this theme has been ported many times
from w7 for w8 then for w8.1 from 8.1 for w10 1507 from 1507 for november update 1511 then from 1511 for 1607 next for rs1-rs5 and now from rs5 for rs6 19h1 1903Last edited by ミறѳѳղղįզվદ彡; June 1st, 2019 at 03:14 AM.
June 16th, 2019 05:44 AM #5
- Jun 2019
- Russia
- 1
- 0 Thread(s)
And onather one bug: context menu on taskbar - when move mouse over menu commands they stay selected even when mouse moved out.
October 16th, 2019 01:54 PM #6
- Oct 2019
- USA
- 1
- 0 Thread(s)
Why doesn't it change the minimize/close buttons? And the file explorer is no different. Just like the old Win 7 theme for Win 10.
Armageddon V1 Aero 7 Theme 4 W10 1903 [H1] RS6
By Donkuz in forum Themes by DonkuzReplies: 13Last Post: October 18th, 2019, 06:31 PM -
By ミறѳѳղղįզվદ彡 in forum Themes for Windows 10 Creators Update +Replies: 2Last Post: March 25th, 2019, 09:02 AM -
Aero Gray theme for windows 7 by Mr GRIm
By sadiq3210 in forum Theme RequestsReplies: 2Last Post: January 21st, 2019, 04:56 AM -
By Mr GRiM in forum Mr GRiM's Windows 7 ThemesReplies: 19Last Post: August 12th, 2017, 07:41 AM -
anyone got a aero windows 7 basic theme
By gondudy in forum RequestsReplies: 4Last Post: March 13th, 2013, 07:10 PM
Thank you:happy::happy:
Office 16 64-bit Color...
