May 28th, 2019 01:27 PM #1
- 5,516
Classic theme for Windows 10 1903
Classic theme for 1903 Support for Ultimate Desktops 4K 5K 8K
By ミறѳѳղղįզվદ彡 in forum Moonnique's Ported ThemesReplies: 2Last Post: February 28th, 2020, 09:41 AM -
By ミறѳѳղղįզվદ彡 in forum Themes for Windows 10 Creators Update +Replies: 1Last Post: March 3rd, 2019, 05:23 PM -
How should I edit this Classic Windows theme?
By davidD in forum Windows 7 Theme Help & SupportReplies: 0Last Post: July 15th, 2018, 10:06 PM -
Classic Theme on Windows 10
By Skarn in forum General Windows 10 CustomizationReplies: 1Last Post: August 21st, 2016, 07:17 PM -
HUD Evolution is the Windows Classic theme
By kirill2485 in forum Theme IssuesReplies: 3Last Post: August 3rd, 2015, 08:24 PM
Lyra Workstation by Niivu Windows 11 22H2+ A new suite based on LYRA'15 by novoo and their setup inspired by the work of imrik
