Results 1 to 6 of 6
Thread: LoL Game VS
June 4th, 2019 10:56 PM #1
- Aug 2014
- Coolidge, AZ, USA
- 1,920
- 2 Post(s)
- 61 Thread(s)
LoL Game VS
With permission from yorgash of DeviantArtWindows 10 RS2 1703 15063
Originally ported to Windows 10 RS2-RS4 by Erin
LoL Game VS
Windows 10 RS3 1709 16299
Windows 10 RS4 1803 17134
Windows 10 RS5 1809 17763
- Immersive Context Menu and Task Scheduler bugs have been fully repaired in this port.
- This port contains versions for Windows 10 RS2 all the way to Windows 10 RS5
Install an iPack of your choice to change the system icons.
