June 6th, 2019 09:02 AM #1
- 5,516
CaseLabs for 1903 by Harvey Sewdin
Harvey Sewdin
CaseLabs theme for Windows 10 1903
CaseLabs for w7
https://virtualcustoms.netcase+labs
CaseLabs theme for
Windows 10 RS2 1703 15063
Windows 10 RS3 1709 16299
Windows 10 RS4 1803 17134
Windows 10 RS5 1809 17763
https://virtualcustoms.net/showthread.php/82448-CaseLabs-by-Harvey-Sewdin
Mr GRiM
CaseLabs Windows 10 TH2 AKA 1511 AKA 10586 Only!!
https://virtualcustoms.net/CaseLabs-Windows-10-TH2-AKA-1511-AKA-10586-Only=case+labs
CaseLabs for Windows 10 Anniversary Update Redstone 1 Only!!
https://virtualcustoms.net/Caselabs-for-Windows-10-Anniversary-Update-Redstone-1?highlight=case+labs
After almost 3 years I present to you a new theme!
This one is based around CaseLabs, a well known and respected computer chassis manufacturer.
I'm quite fond of their cases and decided to dedicate a theme to them.
Also, I tried to make this as monochrome as possible
so any you can match any other color to the theme(or just leave it in black/white).
I would like to thank JLMS2010 and Wiz766 for using their computer build/mod photos as wallpapers.
Their builds and photography skills are amazing and it really matches the theme.
Also, thanks to Razorsedge for pushing me into theming again, he never gave up on me.
And don't forget Lamia for the amazing ports he does, thanks guys.
On the the theme, it supports Aero and partially Basic Windows modes.
There are some extras included with information on how to apply them.
If there are any errors in the theme you can keep me posted, I'll try to fix it if I can.
HOPE YOU LIKE IT
FEATURES
THEME
► CaseLabs Theme
► Cursors
► Startorb, Navigation buttons and CP side images
► Wallpapers
EXTRAS
► Adobe After Effects Splash
► Adobe Audtition Splash
► Adobe Illustrator Splash
► Adobe Photoshop Splash
► Dock Icons
► Fonts
► Logon Pics
► Rocketdock Skin
► Shellbrd Orbs
► System Genuine orb
► TimeDate images
Also, check this wallpaper pack I made out if you're into PC hardware:https://virtualcustoms.net/showthread.php/68593-M-BOARDS-Walls-Collection
JLMS2010 build log: https://www.overclock.net/t/1489129/build-log-case-labs-sma8-transformation
Wiz766 build log: https://www.overclock.net/t/1536966/build-log-titan-x-ensourced-cables-caselabs-x2m/310
WARNINGPlease make sure you download the correct theme file according to your operating system version! Last edited by ミறѳѳղղįզվદ彡; June 6th, 2019 at 10:10 AM.
CaseLabs by Harvey Sewdin
By ミறѳѳղղįզվદ彡 in forum Themes for Windows 10 Creators Update +Replies: 2Last Post: January 3rd, 2019, 05:42 AM -
CaseLabs Windows 8.1.1 Theme
By Lamia in forum Harvey Sewdin's Windows 8 ThemesReplies: 15Last Post: November 20th, 2015, 04:59 PM -
CaseLabs
By Harvey Sewdin in forum Harvey Sewdin's Windows 7 ThemesReplies: 25Last Post: August 25th, 2015, 01:05 PM -
Ben10 Theme by Gor17981 & Harvey Sewdin
By Harvey Sewdin in forum Harvey Sewdin's Windows 7 ThemesReplies: 41Last Post: August 1st, 2013, 11:18 AM -
GREEN-to-BLACK theme by Harvey Sewdin
By Harvey Sewdin in forum Harvey Sewdin's Windows 7 ThemesReplies: 18Last Post: January 5th, 2012, 04:00 PM
Hello world, I am...
