Thread: Nemesis for 1903 by razorsedge
June 8th, 2019 05:51 AM #1
- 5,516
Nemesis theme for Windows 10 1903
Windows 10 RS2 1703 15063
Windows 10 RS3 1709 16299
Windows 10 RS4 1803 17134
Windows 10 RS5 1809 17763
https://virtualcustoms.net/showthread.php/82450-Nemesis-by-razorsedge
Nemesis for w7
https://virtualcustoms.net/Nemesis
freak69ize
Nemesis Windows 10 TH2 AKA 1511 AKA 10586 Only!!
https://virtualcustoms.net/showthread.php/Nemesis-for-Windows-10-TH2-Aka-1511=nemesis
Nemesis for Windows 10 Anniversary Update Redstone 1 Only!!
https://virtualcustoms.net/showthread.php/Nemesis-for-Windows-10-Anniversary-Update-AKA-1607-Aka-RS1=nemesis
NEMESIS
A Big thanks to Mr Grim on this theme even though we like to go toe to toe all of the screens we send back
and forth and advice given could not have done this without you bud thanks so much
A big thanks to all the members and themers that entered the contest thanks so much for all your hard work
and all of you that followed and commented and made this contest such a bit hit and so much fun
Nemesis theme Includes
Custom gadgets
Around aimp skin by Angel AG3
ObjectDock sci-fi skin and icons ( also blank icon to make your own )
Alternate Wallpaper
Shellbrd orb
Systemcpl.dll Image to replace the genuine image in system control panel
Time date.cpl ( clock) images
Custom all new explorerframe.dll Images
Custom Nav Panel ( shell32.dll)
Custom Start orb
Recolored Fire Dragon Cursors by Jacksmafia
Custom Nemesis Sound pack
Nemesis wallpaper
Nemesis extras
(includes)
Aimp skin
Alternate wall
Timedate.cpl images
Shellbrd orb
Systemcpl.dll Image
custom gadgets
Objectdock skin and Icons
Nemesis by razorsedge
By ミறѳѳղղįզվદ彡 in forum Themes for Windows 10 Creators Update +Replies: 2Last Post: December 1st, 2020, 06:47 PM -
Steel Flash W10 1903-2004 by Razorsedge
By Donkuz in forum Themes by DonkuzReplies: 5Last Post: August 7th, 2020, 03:40 PM -
ARMAGEDDON by Razorsedge for Windows 10 1903/1909
By Erin in forum Themes by ErinReplies: 21Last Post: May 3rd, 2020, 08:31 PM -
MS One Red for 1903 by razorsedge Support for Ultimate Desktops 4K 5K 8K
By ミறѳѳղղįզվદ彡 in forum Moonnique's Ported ThemesReplies: 3Last Post: August 23rd, 2019, 08:23 AM -
AC/DC for 1903 by razorsedge Support for Ultimate Desktops 4K 5K 8K
By ミறѳѳղղįզվદ彡 in forum Moonnique's Ported ThemesReplies: 3Last Post: August 21st, 2019, 10:01 PM
Post Your Mobile Theme
