June 23rd, 2019 03:28 AM #1
- Aug 2011
- Atlanta, Georgia
- 1,577
- 280 Thread(s)
HUD Launch For Windows 10 1903 [19H1] thru 2004 (20H1)
HUD LaunchInstalling themes on Windows 10:
For Windows 10 1903 (19H1) thru 2004 (20H1)
Theme By Mr GRiM - Port to 1903 By Dark Knight
imageres.dll images
start button
OldNewExplorer
Aimp Skin
Some Tools You May Need
1.) Create a Restore Point
InformationThe download file says for use on 19H1 only, this is when we did not know if theme ports will work on future versions, so far the theme will work on all versions of Windows 10 AFTER version 1903
HUD Apocalypse Ultimate edition for Windows 10 2004 20h1
By ミறѳѳղղįզվદ彡 in forum Themes by Mr GRiMReplies: 68Last Post: August 14th, 2021, 10:36 PM -
Cant apply theme after upgrade from 1903/1909 19h1/19h2 to 2004/2009 20h1/20h2
By ミறѳѳղղįզվદ彡 in forum Moonnique's Ported ThemesReplies: 2Last Post: July 28th, 2021, 09:56 AM -
H20 Ultimate edition for Windows 10 2004 20h1
By ミறѳѳղղįզվદ彡 in forum Themes by Mr GRiMReplies: 3Last Post: November 7th, 2020, 04:21 PM -
HUD Launch Ultimate edition for Windows 10 2004 20h1
By ミறѳѳղղįզվદ彡 in forum Themes by Mr GRiMReplies: 7Last Post: October 18th, 2020, 12:40 PM -
White Areas Windows 2004 (20H1)
By Dark Knight in forum Miscellaneous questionsReplies: 2Last Post: August 31st, 2020, 01:27 AM
Show Us Your Rig
