Page 7 of 7 FirstFirst ... 34567
Results 37 to 39 of 39
Thread: [TOOL] Se7en Theme Source patcher v0.6 Build 2019 Share
    Fixit is offline
    Skilled
    Mar 2010
    127.0.0.1
    95
    69 Thread(s)
    Clean [TOOL] Se7en Theme Source patcher v0.6 Build 2019
    Se7en Theme Source Patcher
    25 Jun 2019 v0.6 RC1 Build 2019
    ~Create restorepoint fixed for all windows versions
    ~Fixed regedit not being patched on x64 systems
    ~Added a new default skin created by [Only registered and activated users can see links. ]
    ~Added .mun file patching support - any .mun file can be added in *.mun.res format (experimental, not recommended)
    ~Many small script updates
    ~Removed misc options from Extra section
    ~Removed update check from info menu
    7tsp features:
    *7tsp is portable, no need to install
    *More complete modification possible
    *Faster Patching (e.g. 10x faster patching of imageres.dll)
    *Patches any file in *.res format in the following folders:
    system32\ folder on x86 and x64 systems (always has)
    syswow64\ folder on x64 systems (always has)
    Branding\ folder
    en-US\ folder (when your system is e.g. French 7tsp uses fr-FR)
    Speech\ folder
    Migwiz\ folder
    7tsp knows all file locations, just drop your *.res file in the resources folder in your pack and 7tsp figures it out
    *Never patches explorer.exe and shell32.dll on windows 8, 8.1 and 10 systems even if the res file exists in the used pack
    *The backup routine checks and saves all file versions to detect windows update changes
    Tested on:
    Windows 7 x86 and x64
    windows 10 x64 live system
    Extra thanks to:
    [Only registered and activated users can see links. ] for helping with testing the new version
    [Only registered and activated users can see links. ] for creating the new skin
    Kind Regards
  2. #37
    LegzRwheelz is offline
    Feb 2020
    Behind You, In the bushes
    10
    This is really cool! I was wondering though:Is there any way to install an icon pack from command or a batch file? I have a .bat file that I have progressively been adding apps to install with a single launch (redistributables etc) for the times I reinstall windows. It makes things super simple, I just plug in my flash drive which has an autorun file set to launch the .bat and it does the rest. Anyhow, sorry, my add gets to me . So I would love to add 7tsp and a specific theme to automatically install using my batch file. Is this possible?
  3. #38
    றѳѳղղįqվદ® is offline
    💜진정한 지식은💜💜결코 죽지 않는다💜
    💜In Your Heart💜
    25
    4,222
    Information
    "Sorry, 7tsp only works with Windows Se7en!"
    this problem is if you are using the fake version of Windows and not the original license
    this problem is if you are upgrading your os from Windows 7 to higher W8 / W10
    if you are upgrading w10 to the higher build or Insider preview
    before Upgrade run sfc /scannow and remove all of your 7tsp files from c/Program files directory
    because new windows using the old rest data from Old Windows or use Clean Install
  4. #39
    💜In Your Heart💜
    25
    4,222
    Information
    thank you my dear friend
    tested on Windows 11 and works flawlessly
  1. Se7en Theme Source Patcher v0.4 2015
    By றѳѳղղįqվદ® in forum Theme Patchers
    Last Post: 03-03-2019, 07:11 PM
  2. Replies: 124
    Last Post: 05-19-2016, 05:11 AM
  3. 7 Theme Source Patcher
    By Adrian in forum General Questions
    Last Post: 09-24-2015, 09:15 PM
  4. Se7en Theme Source Patcher v0.4 2015
    By றѳѳղղįqվદ® in forum Fixit Tools
    Last Post: 04-10-2015, 03:31 AM
  5. [Tool]Windows Se7en File Replacer v1.5.4
    By Fixit in forum Fixit Tools
    Last Post: 11-05-2010, 10:39 AM
