Results 25 to 30 of 30
Thread: Windows 7, Windows 8, Windows 10 TH2 import to Windows 10 19H1 1903
    Mr GRiM is offline
    Administrator
    5,328
    837 Thread(s)
    Windows 8 to Windows 10 TH2 import to Windows 10 19H1 1903
    Important, do not use this to update any themes newer then Windows 10 TH2, for newer themes go here Windows 10 19H1 1903 Updated ClassMaps and Import Scripts
    This update allows you to update themes from Windows 8 and onwards up to Windows 10 TH2 to the latest Windows 10 1903 19H1.
    Update your theme by using the following instructions.
    For updating a Windows 7 theme to Windows 10 19H1 first use the Windows Style Builder 7-10 TH2 version to update the theme to TH2
    2. Open the WSB Program.
    3. Go to File > Open > Import 7 Theme and Import the Windows 7 theme you want to update.
    4. Save your updated theme, do not test the theme or apply any fix and then proceed to the following steps.
    Update your Windows 8 - Window 10 TH2 theme by following these steps
    1. Open the folder called "Windows Style Builder TH2 - 19H1 1903"
    3. Go to File > Open > Import 7 Theme and Import the theme you want to update.
    4. Select Import Style Hack and select "Windows 10 1903 Import Fix" (Very important!!, do not miss this step!!)
    5. You can now test your Theme and make sure it has imported correctly and does not give you any msstyles errors.
    6. Save your updated theme and you're done.
    Enjoy
    NOTE
    Don't forget to replace the shell folder with the updated one, if you are going to save the updated theme in the same folder then replace the shell folder before you update the theme.
    Information
    Added new Windows Style Builder 7-10 TH2, this version will allow you to import themes from Windows 7 to TH2 but added the parts for 19H1 and retains more of the original theme then the old 7-10TH2, the old one sort of worked but the themes got a bit messed up, there is still one issue with this version though, after the import the Aero Peak background can get messed up, it does not seem to happen with all themes though, just export the one from the original Windows 7 theme then import it to the updated theme.
    Disclaimer, I am not responsible for any one trying out these scripts or for anyone who bricks their system, these are experimental and should be used on a Virtual machine for your safety.
  1. Windows 10 RS6 1903 Updated Class Maps and Import script for Light Mode
    By Mr GRiM in forum Updates & Style Hacks For WSB
    Last Post: April 25th, 2022, 01:42 PM
  2. Windows 10 19H1 1903 Updated ClassMaps and Import Scripts
    Last Post: February 13th, 2022, 06:34 PM
  3. Zero-G for Windows 10 1903 [19H1] ONLY
    Last Post: September 10th, 2020, 09:52 PM
  4. Kemikal For Windows 10 1903 19H1
    Last Post: March 23rd, 2020, 05:33 PM
  5. Windows 10 1903 [19H1]
    By Dark Knight in forum General Discussion
    Last Post: February 10th, 2020, 12:37 PM
