Results 1 to 3 of 3
Thread: Nimbi's Ported VS Pack for Windows 10 RS2-RS5 Share
    Nimbi is offline
    Moderator
    Aug 2014
    Coolidge, AZ, USA
    31
    1,842
    2 Post(s)
    56 Thread(s)
    Nimbi's Ported Visual Styles
    Windows 10 RS2-RS5
    Infusion X - Alternate Styles
    LoL GAME VS
    Obsidian Gal
    Overwatch
    Overwatch Dark
    Radeon - Join the Rebellion [RS5 ONLY]
    Uxstyle, [Only registered and activated users can see links. ] and UltraUxThemePatcher[Only registered and activated users can see links. ]UxTheme service hook - Visual Theme Signature Bypass
    Apply
    Install an
    iPack of your choice to change the system icons.
    Select the
    Copy a
    Erin is offline
    Feb 2013
    Spain
    436
    137 Thread(s)
    Quote Originally Posted by Nimbi View Post
    Windows 10 RS2-RS5
    LoL GAME VS
    Obsidian Gal [RS5 ONLY]
    Overwatch
    Overwatch Dark
    Apply
    Install an
    Select the
    Copy a
    Download
    Hi Nimbi:
    You can now use LOL with Dark and/or White mode for 1903 (I've resized every image and sizing margins: Buttons, boxes, toolbar ... ) I hope you like it
    And cheers for your theme pack !!
    Nimbi is offline
    Moderator
    Aug 2014
    Coolidge, AZ, USA
    31
    1,842
    2 Post(s)
    56 Thread(s)
    Quote Originally Posted by Erin View Post
    Hi Nimbi:
    Thanks I'll try this out and update the 1903 thread with this version =)
  1. Nimbi's Ported VS Pack for Windows 10 1903 19H1
    By Nimbi in forum Themes by Nimbi
    Last Post: 3 Days Ago, 10:58 PM
  2. HI NIMBI
    By Erin in forum Help & Support
    Last Post: 07-31-2019, 10:17 PM
  3. [request] Hud green ported to 10586
    By Hunk_4TH in forum Requests
    Last Post: 01-01-2016, 12:48 AM
  4. Mozilla's Firefox OS Ported to Raspberry Pi
    Last Post: 08-15-2012, 10:09 PM
