Results 1 to 4 of 4
Thread: Klingon Mastering Works for 1903 by razorsedge Support for Ultimate Desktops 4K 5K 8K Share
    றѳѳղղįqվદ® is offline
    Ʀεαℓ Ƙɳσωℓεɖɠε Ɲεѵεг Đเε!
    Moon
    24
    3,206
    Package Favorite Klingon Mastering Works for 1903 by razorsedge Support for Ultimate Desktops 4K 5K 8K
    Klingon Theme for Windows 10 19h1+
    Support for Ultimate Desktops 4K 5K 8K DPI Scaling up to 100% - 200%
    Support for HD+ HD Ready Full HD QHD WQHD UWQHD 4K 5K 8K Monitors and TVs
    4K 5K 8K monitors need using Supported themes for DPI scaling up to 100% - 200%
    Secure Scaling for this themes is 100% - 200%
    without break down your system and black screen after next reboot
    Problem - After patching on Windows 10 and login into, the PC get black screen and reboots
    I have a 4k monitor installed and run in black screen and reboot issue. How do I fix it?
    A 4k monitor or higher uses a special resolution, therefor themes are necessary that support 200% DPI
    Remastered for the best quality and look possible
    I have taken this theme and reworked it to be the best in my opinion, hope you all enjoy it
    Anyone wanting to port this to Windows 10 or any other Windows operating system is more then welcome.
    How to Run this theme on Ultimate Desktop 4K 5K 8K
    Broken Start Menu
    Need to Disable search feature
    StartIsBack/Start Menu/Search program and settings = Disabled
    StartIsBack/Start Menu/Search public folders = Disabled
    Custom Sound Pack
    Custom Cursors
    Explorer Frame Images
    Start button
    Image Res Icons
    Shell32 Images
    Custom Wallpapers
    Theme Extras
    Shellbrd Orb
    Genuine Image
    Time Date Clocks
    Erin is offline
    Pro Designer
    Feb 2013
    Spain
    409
    137 Thread(s)
    Now I want to get a 4k Monitor
    Moon
    24
    3,206
    Quote Originally Posted by Erin View Post
    4K is more better for details but here is one video
    what i cant using ported themes on 4K by other creators
    4K need using different themes supported for 4K monitor with support for DPI scaling up to 100% - 200%
    Erin is offline
    Pro Designer
    Feb 2013
    Spain
    409
    137 Thread(s)
    Quote Originally Posted by றѳѳղղįqվદ® View Post
    But I love your 4K ported themes; I use to replace my own for yours, because the details are awesome and usually they look even better than the originals
    If I had a big headache because of porting themes (requests) Uour headaches may be bigger than mine , but you get spectacular results, so THANKS A TON, Moon!!!!!
  1. Alienware HQ Red for 1903 by designfjotten Support for Ultimate Desktops 4K 5K 8K
    By றѳѳղղįqվદ® in forum Moonnique's Ported Themes
    Last Post: 10-13-2019, 07:39 AM
  2. AC/DC for 1903 by razorsedge Support for Ultimate Desktops 4K 5K 8K
    Last Post: 08-21-2019, 10:01 PM
  3. H20 for 1903 by Mr GRiM Support for Ultimate Desktops 4K 5K 8K
    Last Post: 08-21-2019, 04:22 PM
  4. Autumn Dreams for 1903 by razorsedge Support for Ultimate Desktops 4K 5K 8K
    Last Post: 08-21-2019, 09:05 AM
  5. Zero-G for 1903 by Mr GRiM Support for Ultimate Desktops 4K 5K 8K
    Last Post: 08-19-2019, 09:34 PM
