Results 1 to 4 of 4
Thread: Klingon Mastering Works for 1903 by razorsedge Support for Ultimate Desktops 4K 5K 8K Share
    றѳѳղղįqվદ® is offline
    Ʀεαℓ Ƙɳσωℓεɖɠε Ɲεѵεг Ðเε!
    Moon
    24
    3,380
    Package Favorite Klingon Mastering Works for 1903 by razorsedge Support for Ultimate Desktops 4K 5K 8K
    Klingon Theme for Windows 10 19h1+
    Remastered for the best quality and look possible
    I have taken this theme and reworked it to be the best in my opinion, hope you all enjoy it
    Anyone wanting to port this to Windows 10 or any other Windows operating system is more then welcome.
    Broken Start Menu
    Custom Sound Pack
    Custom Cursors
    Explorer Frame Images
    Start button
    Image Res Icons
    Shell32 Images
    Custom Wallpapers
    Genuine Image
    Time Date Clocks
    Erin is offline
    Feb 2013
    Spain
    436
    137 Thread(s)
    Now I want to get a 4k Monitor
    Moon
    24
    3,380
    Quote Originally Posted by Erin View Post
    4K is more better for details but here is one video
    what i cant using ported themes on 4K by other creators
    4K need using different themes supported for 4K monitor with support for DPI scaling up to 100% - 200%
    Erin is offline
    Feb 2013
    Spain
    436
    137 Thread(s)
    But I love your 4K ported themes; I use to replace my own for yours, because the details are awesome and usually they look even better than the originals
    If I had a big headache because of porting themes (requests) Uour headaches may be bigger than mine , but you get spectacular results, so THANKS A TON, Moon!!!!!
  1. Alienware HQ Red for 1903 by designfjotten Support for Ultimate Desktops 4K 5K 8K
    Last Post: 03-01-2020, 01:37 PM
  2. AC/DC for 1903 by razorsedge Support for Ultimate Desktops 4K 5K 8K
    Last Post: 08-21-2019, 10:01 PM
  3. H20 for 1903 by Mr GRiM Support for Ultimate Desktops 4K 5K 8K
    Last Post: 08-21-2019, 04:22 PM
  4. Autumn Dreams for 1903 by razorsedge Support for Ultimate Desktops 4K 5K 8K
    Last Post: 08-21-2019, 09:05 AM
  5. Zero-G for 1903 by Mr GRiM Support for Ultimate Desktops 4K 5K 8K
    Last Post: 08-19-2019, 09:34 PM
