Results 1 to 4 of 4
Thread: MS One Red for 1903 by razorsedge Support for Ultimate Desktops 4K 5K 8K
    ミறѳѳղղįզվદ彡 is offline
    Co-Admin♀ Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young
    🌸In the Future🌸
    5,510
    Package Favorite MS One Red for 1903 by razorsedge Support for Ultimate Desktops 4K 5K 8K
    razorsedge
    Maximum Security One Red for Windows 10 19h1+
    Support for Ultimate Desktops 4K 5K 8K DPI Scaling up to 100% - 200%
    Support for HD+ HD Ready Full HD QHD WQHD UWQHD 4K 5K 8K Monitors and TVs
    4K 5K 8K monitors need using Supported themes for DPI scaling up to 100% - 200%
    Secure Scaling for this themes is 100% - 200%
    without break down your system and black screen after next reboot
    Problem - After patching on Windows 10 and login into, the PC get black screen and reboots
    I have a 4k monitor installed and run in black screen and reboot issue. How do I fix it?
    A 4k monitor or higher uses a special resolution, therefor themes are necessary that support 200% DPI
    https://virtualcustoms.net/3rd-Party-Themes-Support-for-Ultimate-Desktops-4K-5K-8K
    MS: One
    It's the worlds most secure prison
    It holds the planets deadliest criminals
    It's impenetrable
    because its not on earth
    Remastered for the best quality and look possible
    I have taken this theme and reworked it to be the best in my opinion, hope you all enjoy it
    Anyone wanting to port this to Windows 10 or any other Windows operating system is more then welcome.
    How to Run this theme on Ultimate Desktop 4K 5K 8K
    Broken Start Menu
    Need to Disable search feature
    StartIsBack/Start Menu/Search program and settings = Disabled
    StartIsBack/Start Menu/Search public folders = Disabled
    Apply
    Install an
    Select the
    Copy a
    devillnside is offline
    Elite
    Aug 2012
    Dhaka, Bangladesh
    1,458
    1 Post(s)
    51 Thread(s)
    awesome work moon!!! porting all these themes to 1903... you've been busy!!
    D@rkside Of Aquarius™
    easel is offline
    Skilled
    Jul 2011
    Leeds
    200
    179 Thread(s)
    Dido....!!! ! You sure have Moon thanks so much for the works & shares updating these classics now... Many thanks again all works appreciated...
    Ultimitmale is offline
    Pro Designer
    Apr 2013
    Northern Ireland UK
    257
    14 Thread(s)
    Didn't take long for Moon to get back to the fast uploads after just back from vacation, she is always busy and where she gets the time and energy from blows me away.
    Just a pity that there are only a handfull of posts of thanks or remarks compared to the downloads, and this applies to ALL the Themers who work here to share what you ALL enjoy creating.
    ASUS ROG STRIX B550-F Gaming - Ryzen 5 3600XT
    Corsair Vengeance LPX 32GB 3200Mhz - ASUS ROG STRIX RTX 3060
    AUSS ROG Claymore Keyboard - ASUS ROG Spatha Mouse
  1. Hardwired Red for 1903 by razorsedge Support for Ultimate Desktops 4K 5K 8K
    By ミறѳѳղղįզվદ彡 in forum Moonnique's Ported Themes
    Last Post: May 9th, 2022, 01:37 PM
  2. Magnum Light for 1903 by razorsedge Support for Ultimate Desktops 4K 5K 8K
    Last Post: September 11th, 2020, 12:49 AM
  3. Chrononaut for 1903 by razorsedge Support for Ultimate Desktops 4K 5K 8K
    Last Post: August 24th, 2019, 02:27 AM
  4. MS One Green for 1903 by razorsedge Support for Ultimate Desktops 4K 5K 8K
    Last Post: August 22nd, 2019, 01:07 PM
  5. AC/DC for 1903 by razorsedge Support for Ultimate Desktops 4K 5K 8K
    Last Post: August 21st, 2019, 10:01 PM
