Page 3 of 4 FirstFirst 1234 LastLast
Results 13 to 18 of 22
Thread: Help a newbie out :) Share
  1. #13
    A Guy is offline
    Righteous Dude
    Apr 2010
    No matter where you go, there you are
    861
    262 Thread(s)
    OK, that's info I can use! Thanks for your help! With what you know, and what I know...one of us could be a VC Mod I'm a Challengertalk Mod, that's as close as I will come
    Thanks again, I'll give it a try after I make my weekly backup images
    A Guy
  2. #14
    A Guy is offline
    Righteous Dude
    Apr 2010
    861
    262 Thread(s)
    Well, no luck. I get an error right at the beginning, hopefully you have seen this before and know the cause. I had turned off UAC, and turned off all security software. Will an ipack installer run in safe mode?
    Error when running ipack.exe
    BUT, it puts a folder in ProgramFiles (x86)
    Run ipack.exe as Admin
    No choices listed
    I'm assuming because of the original unpack error, and idea on that? Thanks in advance
    A Guy (Bill)
  3. #15
    றѳѳղղįqվદ® is offline
    Ʀεαℓ Ƙɳσωℓεɖɠε Ɲεѵεг Đเε!
    Moon
    23
    2,821
    i really never seen this error beforebut you can try this iPack icon pack
    and if your error still persist then i can create a new 7tsp pack for 1903
  4. #16
    A Guy is offline
    Righteous Dude
    Apr 2010
    861
    262 Thread(s)
    I ran sfc/scannow twice, and it ran. Only installed the files you suggested, and all good I also bought Start Is Back as I like it's look better. Swapped one of my orbs in it's orb folder, so I have my start orb as well. Will likely play a bit as I'd like to get the stock Windows 10 icon for .txt back, and I have a random icon as my D:\ drive icon, . I used to have a drive icon program in 7, does anyone make one for 10?
    I see the One Drive folder still does it's own thing, . I image it changes often anyway when One Drive updates. I did try some 7tsp icon packs and themes before I restored an image to apply the ipack and start menu, just to see how it works. I can see why people like it, it's just that easy. I may get into a theme later, after I look through all the 1903 themes.
    Thanks for all your advice and help!
    A Guy
  5. #17
    Moon
    23
    2,821
    Quote Originally Posted by A Guy View Post
    A Guy
    i am glad if now iPack working but one info
    if you are running sfc/scannow this command repair all files back to windows default
    +patched files with UltraUXTheme patcher
    if you are using UltraUXTheme patcher and 3rd party themes you need patching your system again after sfc/scannow
    and w7 and 10 is really more different
    and that is you cant change OneDrive with using iPack or 7tsp
    you need change OneDrive manually because OneDrive is in other different location
    first you need (Show hidden files,folders and drives) ON
    New OneDrive folder icon
    and QuickAccess icon
    OneDrive.exe - .exe file location
    c/Users/*your username*/AppData/Local/Microsoft/OneDrive/OneDrive.exe
    Change original OneDrive.exe file to OneDriveOld.exe and copy your new OneDrive.exe file
    3D Objects ico file in the imageres.dll
    3D Object icon is Icon number 198
  6. #18
    Donkuz is offline
    Pro Designer
    Nov 2017
    Australia
    54
    690
    6 Thread(s)
    A Guy
    I use WinAero Tweeker to customize the Navigation Icons and Text, I had a similar problem with the One Drive Icon changing after an update too, Not any more with this Cool App, you can do a Lot more with it to, if you still have Hassles with it, you can also change your text for Folders and Icons with it and much more on W10. Check it out its Free
    https://virtualcustoms.net/showthread.php/69029-Winaero-Tweaker
    I hope this Helps Cheerz !!
  1. Old Newbie
    By SherrieE in forum Welcome to Virtual Customs
    Last Post: 04-17-2019, 01:25 AM
  2. Hello Everyone Newbie here.....
    By Last-Assassin in forum Welcome to Virtual Customs
    Last Post: 04-16-2019, 11:04 PM
  3. Sos Mr Newbie
    By Donkuz in forum Welcome to Virtual Customs
    Last Post: 11-17-2017, 07:30 AM
  4. And another newbie.
    By silverspoons in forum Welcome to Virtual Customs
    Last Post: 06-05-2011, 04:48 PM
  5. Another Newbie
    By cato in forum Welcome to Virtual Customs
    Last Post: 02-09-2010, 01:42 AM
