Results 1 to 2 of 2
Thread: Help - New Alienware 34 Curved Gaming Monitor - AW3420DW Share
    றѳѳղղįqվદ® is online now
    Ʀεαℓ Ƙɳσωℓεɖɠε Ɲεѵεг Ðเε!
    Moon
    23
    3,111
    Ktip Help - New Alienware 34 Curved Gaming Monitor - AW3420DW
    Help please Xmas coming
    hello friends
    please anybody here who know help to me with this new Nano-Ips monitor by DELL
    is this a good 1440p monitor to the future or? because high price and no HDR support
    any help very welcome
    Device Type
    LED-backlit LCD monitor
    Features
    USB 3.0
    Panel Type
    Fast IPS Nano Color
    Aspect Ratio
    21:9
    Native Resolution
    3440 x 1440 at 120Hz (native)
    Pixel Pitch
    0.2325 mm x 0.2325 mm
    Brightness
    350 cd/m2 (typical)
    Contrast Ratio
    1000: 1 (typical)
    Response Time
    True 2ms (Gray to Gray)
    Color Support
    Color Gamut (typical): DCI- P3 98% coverage
    Color Depth: 16.78 Million colors
    Input Connectors
    1 x HDMI (ver 1.4)
    1 x DP (ver 1.2)
    1 x USB 3.0 upstream port (Rear)
    2 x USB 3.0 Downstream port (Rear)
    2 x USB 3.0 Downstream port with 1 x power charging(Front bottom)
    1 x Headphone-out jack (Front Bottom)
    1 x Audio Line-out jack( Rear)
    Display Position Adjustments
    799.80 mm x 334.80 mm
    31.49" x 13.18"
    267773.04 mm2 (415.01 inches2)
    Screen Coating
    Antiglare with 3H hardness
    Dimensions (WxDxH) - with stand
    32.04"x10.77"x22.10"
    Weight
    15.67kg
    34.54 lb
    Compliant Standards
    Product Safety, EMC and Environmental Datasheets
    Dell Regulatory Compliance Home Page
    Dell and the Environment
    Product Description
    Alienware 34 Inch Curved Gaming Monitor - AW3420DW
    Diagonal Size
    86.7 cm
    34.1 Inches
    See less
    General
    Display Type
    LED-backlit LCD monitor / TFT active matrix
    Diagonal Size
    34.1"
    Viewable Size
    34.1"
    Curved Screen
    Yes (1900R)
    Adaptive-Sync Technology
    NVIDIA G-SYNC
    Built-in Devices
    USB 3.0 hub
    Panel Type
    IPS
    Aspect Ratio
    21:9
    Native Resolution
    WQHD 3440 x 1440 at 120 Hz
    Pixel Pitch
    0.2325 mm
    Pixel Per Inch
    110
    Brightness
    350 cd/m²
    Contrast Ratio
    1000:1
    Color Support
    16.8 million colors
    Response Time
    2 ms (gray-to-gray)
    Horizontal Viewing Angle
    178
    Vertical Viewing Angle
    178
    Screen Coating
    Anti-glare, 3H Hard Coating
    Backlight Technology
    LED backlight
    Features
    LED edgelight system, On-screen Digital Controls, Nano IPS, DCI-P3 98% color gamut
    Dimensions (WxDxH)
    32 in x 10.8 in x 22.1 in - with stand
    Weight
    34.55 lbs
    Connectivity
    Interfaces
    • HDMI
    • DisplayPort (DisplayPort 1.2 mode)
    • USB 3.0 downstream (Type A)
    • USB 3.0 downstream with Power Charging (Type A)
    • USB 3.0 upstream
    • Audio line-out
    • Headphones
    Mechanical
    Height, swivel, tilt
    Tilt Angle
    -5/+21
    Swivel Angle
    40
    Height Adjustment
    5.1 in
    VESA Mounting Interface
    100 x 100 mm
    Miscellaneous
    Included Accessories
    Cable cover, stand base
    Cables Included
    • 1 x DisplayPort cable - DisplayPort to DisplayPort
    • 1 x Mini DisplayPort-DisplayPort cable - miniDisplayPort to DisplayPort
    • 1 x SuperSpeed USB cable
    Compliant Standards
    EMC
    Power
    Voltage Required
    AC 120/230 V (50/60 Hz)
    Power Consumption Operational
    58 Watt
    Power Consumption Stand by
    0.3 Watt
    Power Consumption Sleep
    0.3 Watt
    Power Consumption (Off Mode)
    0.3 Watt
    On / Off Switch
    Yes
    Dimensions & Weight
    Dimensions & Weight Details
    • With stand - width: 32 in - depth: 10.8 in - height: 22.1 in - weight: 34.5 lbs
    • Without stand - width: 32 in - depth: 4.8 in - height: 14.3 in - weight: 15 lbs
    Dimensions & Weight (Shipping)
    Shipping Weight
    37.26 lbs
    Manufacturer Warranty
    Bundled Services
    3-Year Advanced Exchange Service and Premium Panel Exchange
    Environmental Parameters
    Min Operating Temperature
    32 °F
    Max Operating Temperature
    104 °F
    Humidity Range Operating
    10 - 80% (non-condensing)
    chevy350 is offline
    Skilled
    Dec 2011
    Ohio
    45
    162
    1 Post(s)
    123 Thread(s)
    specs look good, just not into the curved monitors personally....but if the price is decent compared to other with same features would consider it
  1. Replies: 0
    Last Post: 01-24-2019, 01:00 PM
  2. Replies: 0
    Last Post: 06-29-2018, 12:00 PM
  3. AOC AG352UCG Curved G-Sync Gaming Monitor Review
    By Feed Monkey in forum Latest Articles
    Last Post: 11-06-2017, 01:59 PM
  4. HP Goes Big, Wide, And Curved With Omen X Gaming Monitor
    By Feed Monkey in forum Latest News
    Last Post: 01-04-2017, 01:00 PM
  5. Replies: 0
    Last Post: 07-14-2016, 01:00 PM
