Results 1 to 2 of 2
December 11th, 2019 01:37 PM #1
- 5,503
Help - New Alienware 34 Curved Gaming Monitor - AW3420DW
Help please Xmas cominghello friends
please anybody here who know help to me with this new Nano-Ips monitor by DELL
is this a good 1440p monitor to the future or? because high price and no HDR support
any help very welcome
https://www.dell.com/en-us/shop/new-alienware-34-curved-gaming-monitor-aw3420dw/apd/210-atzq/monitors-monitor-accessories
Device Type
LED-backlit LCD monitor
Features
USB 3.0
Panel Type
Fast IPS Nano Color
Aspect Ratio
21:9
Native Resolution
3440 x 1440 at 120Hz (native)
Pixel Pitch
0.2325 mm x 0.2325 mm
Brightness
350 cd/m2 (typical)
Contrast Ratio
1000: 1 (typical)
Response Time
True 2ms (Gray to Gray)
Color Support
Color Gamut (typical): DCI- P3 98% coverage
Color Depth: 16.78 Million colors
Input Connectors
1 x HDMI (ver 1.4)
1 x DP (ver 1.2)
1 x USB 3.0 upstream port (Rear)
2 x USB 3.0 Downstream port (Rear)
2 x USB 3.0 Downstream port with 1 x power charging(Front bottom)
1 x Headphone-out jack (Front Bottom)
1 x Audio Line-out jack( Rear)
Display Position Adjustments
799.80 mm x 334.80 mm
31.49" x 13.18"
267773.04 mm2 (415.01 inches2)
Screen Coating
Antiglare with 3H hardness
Dimensions (WxDxH) - with stand
32.04"x10.77"x22.10"
Weight
15.67kg
34.54 lb
Compliant Standards
Product Safety, EMC and Environmental Datasheets
Dell Regulatory Compliance Home Page
Dell and the Environment
Product Description
Alienware 34 Inch Curved Gaming Monitor - AW3420DW
Diagonal Size
86.7 cm
34.1 Inches
See less
General
Display Type
LED-backlit LCD monitor / TFT active matrix
Diagonal Size
34.1"
Viewable Size
34.1"
Curved Screen
Yes (1900R)
Adaptive-Sync Technology
NVIDIA G-SYNC
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
WQHD 3440 x 1440 at 120 Hz
Pixel Pitch
0.2325 mm
Pixel Per Inch
110
Brightness
350 cd/m²
Contrast Ratio
1000:1
Color Support
16.8 million colors
Response Time
2 ms (gray-to-gray)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare, 3H Hard Coating
Backlight Technology
LED backlight
Features
LED edgelight system, On-screen Digital Controls, Nano IPS, DCI-P3 98% color gamut
Dimensions (WxDxH)
32 in x 10.8 in x 22.1 in - with stand
Weight
34.55 lbs
Connectivity
Interfaces
- HDMI
- DisplayPort (DisplayPort 1.2 mode)
- USB 3.0 downstream (Type A)
- USB 3.0 downstream with Power Charging (Type A)
- USB 3.0 upstream
- Audio line-out
- Headphones
Mechanical
Height, swivel, tilt
Tilt Angle
-5/+21
Swivel Angle
40
Height Adjustment
5.1 in
VESA Mounting Interface
100 x 100 mm
Miscellaneous
Included Accessories
Cable cover, stand base
Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort
- 1 x Mini DisplayPort-DisplayPort cable - miniDisplayPort to DisplayPort
- 1 x SuperSpeed USB cable
Compliant Standards
EMC
Power
Voltage Required
AC 120/230 V (50/60 Hz)
Power Consumption Operational
58 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
Yes
Dimensions & Weight
Dimensions & Weight Details
- With stand - width: 32 in - depth: 10.8 in - height: 22.1 in - weight: 34.5 lbs
- Without stand - width: 32 in - depth: 4.8 in - height: 14.3 in - weight: 15 lbs
Dimensions & Weight (Shipping)
Shipping Weight
37.26 lbs
Manufacturer Warranty
Bundled Services
3-Year Advanced Exchange Service and Premium Panel Exchange
Environmental Parameters
Min Operating Temperature
32 °F
Max Operating Temperature
104 °F
Humidity Range Operating
10 - 80% (non-condensing)
