Results 1 to 3 of 3
Thread: Teek Modern for 1903 by DevilsBrand® Support for Ultimate Desktops 4K 5K 8K Share
    றѳѳղղįqվદ® is offline
    Ʀεαℓ Ƙɳσωℓεɖɠε Ɲεѵεг Šเε!
    Moon
    24
    3,528
    Package Favorite Teek Modern for 1903 by DevilsBrand® Support for Ultimate Desktops 4K 5K 8K
    DevilsBrand®/[Only registered and activated users can see links. ]
    Teek Modern for Windows 10 1903/1909 19h1+
    Support for Ultimate Desktops 4K 5K 8K DPI Scaling up to 100% - 200%
    Support for HD+ HD Ready Full HD QHD WQHD UWQHD 4K 5K 8K Monitors and TVs
    4K 5K 8K monitors need using Supported themes for DPI scaling up to 100% - 200%
    Secure Scaling for this themes is 100% - 200%
    without break down your system and black screen after next reboot
    Problem - After patching on Windows 10 and login into, the PC get black screen and reboots
    I have a 4k monitor installed and run in black screen and reboot issue. How do I fix it?
    A 4k monitor or higher uses a special resolution, therefor themes are necessary that support 200% DPI
    Donkuz is offline
    Pro Customizer
    Nov 2017
    Australia
    55
    988
    11 Thread(s)
    This is a really Clean looking theme I used to use it a lot a while ago it's good to see it made W10 1903+ Nice work porting and adding support for Scaling 100%-200% Keep up the Great work Moon.
    Cheerz!!
    Moon
    24
    3,528
    Quote Originally Posted by Donkuz View Post
    Cheerz!!
    my pleasure
  1. AC/DC for 1903 by razorsedge Support for Ultimate Desktops 4K 5K 8K
    By றѳѳղղįqվદ® in forum Moonnique's Ported Themes
    Last Post: 08-21-2019, 10:01 PM
  2. H20 for 1903 by Mr GRiM Support for Ultimate Desktops 4K 5K 8K
    Last Post: 08-21-2019, 04:22 PM
  3. Zero-G for 1903 by Mr GRiM Support for Ultimate Desktops 4K 5K 8K
    Last Post: 08-19-2019, 09:34 PM
  4. Teek Modern for Windows 7 by DevilsBrand®
    By Mr GRiM in forum Mr GRiM's Windows 7 Themes
    Last Post: 04-11-2017, 03:17 PM
  5. Teek Modern for Windows 7 by DevilsBrand®
    By Mr GRiM in forum Premium Windows 7 Themes
