Results 7 to 12 of 12
February 16th, 2020 02:18 PM #1
- Nov 2017
- Australia
- 1,328
- 11 Thread(s)
Skyrim Dragon Spawn v1 for W10 1903-1909
ELDERS SCROLLS V SKYRIM COLD STEEL by Razorsedge
DRAGON SPAWN V1by Donkuz
OK Guys n Gals Im Proud to Release this updated version of Elders Scroll V Skyrim Cold Steel by Razorsedge, I gave it a burst of Color with 8 HD Full Colored Wallpapers and a lot of recoloring and Customizing for W10 1903 to W10 1909
Installation Warning
(Recommended for first Setup)
Before Attempting to Install any of the System Mods, Create a Restore Point and or a System Backup Image.
After which you can now go ahead and Begin installation,
Step 1. Apply the Theme Patcher First, I use UltraUXThemepatcher 3.7.1
Now log out and back in again and now your System has been Patched.
Step 2. Install ONE, I use OldNewExplorer 1.1.9 Simply Install then Configure to your likes.
Step 3.Now go ahead and Install StartIsBack for your Classic Start Menu and Taskbar.
After you have these setup your theme should be ready to select from Either The Classic Control Panel or Personalization Settings, if for some reason the Start Menu or the start button hasn't loaded open the Configurations for StartIsBack and Select it from there, the Start Button is in the explorer.exe folder within the theme's Folder.
Everthing you need can be found in my One Drive Share Folder look for Tools@Mods.4W10.1903+
Below.
Available by Request For Legitimate Members Only
https://virtualcustoms.net/member.php/315813-Donkuz
Special Thanks go to Razorsedge for the Elders Scroll V Syrim Cold Steel Original and Moonnique for Porting these Exellent Icons to W10 1903+
and all your help to finish off this Amazing Theme for us to share.
I Hope you Like it Guyz.
Last edited by Donkuz; August 25th, 2021 at 05:02 AM. Reason: Removed Direct Link For Security Reasons
ASUS TUF for Windows 10 1903/1909
By Erin in forum Themes by ErinReplies: 4Last Post: July 9th, 2021, 08:06 AM -
Strata-X for 1909 & 1903
By devillnside in forum Themes by devillnsideReplies: 70Last Post: March 15th, 2021, 07:57 PM -
Context Menu (1903 and 1909)
By tistou77 in forum General Windows 10 CustomizationReplies: 14Last Post: November 17th, 2020, 02:41 AM -
By Donkuz in forum VC Group ThemesReplies: 6Last Post: February 19th, 2020, 08:48 PM -
Simplex for 1903-1909
By devillnside in forum Themes by devillnsideReplies: 23Last Post: January 19th, 2020, 11:02 PM
