Results 1 to 4 of 4
Thread: Event Horizon Supernova for 1903 by razorsedge Support for Ultimate Desktops 4K 5K 8K Share
    றѳѳղղįqվદ® is offline
    Ʀεαℓ Ƙɳσωℓεɖɠε Ɲεѵεг Đเε!
    Moon
    24
    3,295
    Package Favorite Event Horizon Supernova for 1903 by razorsedge Support for Ultimate Desktops 4K 5K 8K
    Event Horizon by Razorsedge
    Supernova for Windows 10 1903 19h1+
    Remastered and fixed File Explorer , Taskbar , Start menu
    Navigation buttons .etc for Ultra Quality
    4K 5K 8K monitors need using Supported themes with DPI scaling up to 100% - 200%
    Original Theme
    Theme 4K+ Ultra Quality
    Thread has been updated
    Theme has been fixed for
    Taskbar version 1
    Taskbar version 2
    Taskbar version 3
    Small Taskbar buttons / Off
    Broken Start Menu
    Custom Sound Pack
    Custom Cursors
    Explorer Frame Images
    Start button
    Image Res Icons
    Shell32 Images
    Custom Wallpaper
    Objectdock Skin
    Genuine Image
    Time Date Clocks
    Moon
    24
    3,295
    Taskbar version 1
    Taskbar version 2
    Taskbar version 3
    devillnside is offline
    Elite
    Aug 2012
    Dhaka, Bangladesh
    39
    1,285
    14 Thread(s)
    wow!!! this looks fantastic!!! beautifully done moon!!!!
    Moon
    24
    3,295
    Information
    added Video preview
  1. Hardwired Red for 1903 by razorsedge Support for Ultimate Desktops 4K 5K 8K
    Last Post: 11-06-2019, 02:10 PM
  2. Chrononaut for 1903 by razorsedge Support for Ultimate Desktops 4K 5K 8K
    Last Post: 08-24-2019, 02:27 AM
  3. MS One Red for 1903 by razorsedge Support for Ultimate Desktops 4K 5K 8K
    Last Post: 08-23-2019, 08:23 AM
  4. MS One Green for 1903 by razorsedge Support for Ultimate Desktops 4K 5K 8K
    Last Post: 08-22-2019, 01:07 PM
  5. AC/DC for 1903 by razorsedge Support for Ultimate Desktops 4K 5K 8K
    Last Post: 08-21-2019, 10:01 PM
