Results 1 to 6 of 6
June 8th, 2020 02:27 PM #1
- 5,503
DMG-SiB by gsw953 and innuendo for Windows 10 19h1+
gsw953
https://virtualcustoms.net/DMG-SiB-For-Windows-10-Creators-Update
innuendo
https://virtualcustoms.net/Theme-by-Innuendo-%28-Yoda-San-%29?highlight=dark+minimal+glassDMG-SiB theme for Windows 10 19h1+
This is a version Innuendo's Dark Minimal Glass
that adds support for Start is Back
This theme is easily user customizable by
changing the Accent Color, which will change
both the active titlebar and the taskbar
You can further customize the taskbarRelics of another world by ahabkaba
in the SiB setting.So any combination
can be achieved to match your favorite
wallpaper!
the Wallpaper seen below is
