Aegis X - Pink Edition
Windows 10 19H1 1903
Windows 10 19H2 1909
Windows 10 20H1 v2004
Uxstyle, [Only registered and activated users can see links. ] and UltraUxThemePatcher[Only registered and activated users can see links. ]UxTheme service hook - Visual Theme Signature Bypass
Credits:
devillnside for the base theme used and for helping with the recolor
