Page 1 of 2 12 LastLast
Results 1 to 6 of 10
Thread: HUD Apocalypse Ultimate edition for Windows 10 2004 20h1 Share
    றѳѳղղįqվદ® is offline
    Ʀεαℓ Ƙɳσωℓεɖɠε Ɲεѵεг Ðเε!
    Moon
    24
    3,414
    Package Favorite HUD Apocalypse Ultimate edition for Windows 10 2004 20h1
    Ultimate edition
    HUD Apocalypse Theme
    7tsp HUD Apocalypse Ultimate Icon Pack
    Many , many and many hours
    The first Ultimate Icon Pack for Windows 10
    Includes 65 .res files
    Windows media player skin
    Task Manager .etc
    7tsp HUD Apocalypse Icon Pack for Windows 10
    Moonnique®
    Task Manager .etc
    7tsp HUD Apocalypse MUI Side Images
    MUI Side Images for Windows 10 2004 20h1
    HUD Apocalypse MUI Side Images by gor17981
    Additional Theme Extras
    AIMP 3 Skin thanks to Gor
    WINRAR Skin thanks to Gor
    Digital Circuits ROG Special edition RED Logon screen thanks to designfjotten
    I
    nstallation:
    Click on Start Patching.
    pinkfloyder is offline
    Jun 2011
    96
    3 Thread(s)
    These are fantastic, many many thanks!!
    Moon
    24
    3,414
    Information
    Thread has been updated
    added HUD Apocalypse Theme Extras
    Jun 2011
    96
    3 Thread(s)
    Many many thanks for the extras!!
    Mr GRiM is offline
    Administrator
    42
    5,424
    769 Thread(s)
    Thanks றѳѳղղįqվદ, looks like you have put a tone of work in to this, it's also the icon set I am still using since I released this theme
    Donkuz is offline
    Pro Customizer
    Nov 2017
    Australia
    55
    935
    6 Thread(s)
    Thanks for this Moonnique and Mr GRiM. This is really Cool Guy'z, I love all the HUD themes and started learning how to apply a Custom Theme with Evolution, This is a really Great Bundle of Sweets!! All your Hard Work was really worthwhile Guy'z
    Thanks for Sharing it with us allCheerz!!
  1. Replies: 4
    Last Post: 1 Week Ago, 04:31 PM
  2. 7tsp Gen-2 Complete Icon Pack Collection for w10 2004 20h1
    By றѳѳղղįqվદ® in forum 7tsp Icon Packs
    Last Post: 1 Week Ago, 06:25 PM
  3. Windows 10 20h1 2004 OS build 19041 Important INFO for Icon Pack Makers/Users
    Last Post: 1 Week Ago, 12:15 PM
  4. Windows 10 20h1 May 2020 update version 2004 OS build 19041 x32 x64 free Download ISO
    Last Post: 4 Weeks Ago, 07:26 PM
  5. StartIsBack++ 2.9 Supports Windows 10 version 20H1 2004
    By றѳѳղղįqվદ® in forum General Windows 10 Customization
    Last Post: 05-03-2020, 01:08 AM
