Page 3 of 4 FirstFirst 1234 LastLast
Results 13 to 18 of 19
Thread: Right Click- taskbar issue Share
  1. #13
    Syryus is offline
    Feb 2017
    Hamburg
    31
    Thank you very much
    I try to find out the location for the start menu ( StartisBack - classic switched ) background color
    Here on this printscreen ( pdf ) it says : Start menu / panels / aero / top / program list
    But I can't find it
    Where exactly is the Start Menu option, on the WSB ?
    I have 2 : on is on the Windows Legacy and one is on the WSB main menu
  2. #14
    Donkuz is offline
    Pro Customizer
    Nov 2017
    Australia
    55
    935
    6 Thread(s)
    Quote Originally Posted by Syryus View Post
    Thank you very much
    But I can't find it
    Dont use the Windows legacy Start Heres the location your looking for below, ps Sorry I had to go before I finished helping you yesterday Im glad you got it sorted.
    I Hope this helps Mate.
  3. #15
    Syryus is offline
    Feb 2017
    Hamburg
    31
    Do I need to import some Stylehack, again ?
    I can't expand the " panels " menu, like in your printscreen
    I'm using StartisBack with the option " classic "
    Thank you, again
  4. #16
    Donkuz is offline
    Pro Customizer
    Nov 2017
    Australia
    55
    935
    6 Thread(s)
    Thank you, again
    No worries Mate, There are a couple of options in the Style Hacks, you need to add Start menu skinning using the same method as before, Hold the shift Key and select Import Style hack and select from the list which one you want to add and apply it then save it and then test it after it has saved to see the Classes you Imported, have a look and see if you need to add taskbar skinning to and do them both together if you need or just use the add Start Menu option.
  5. #17
    Syryus is offline
    Feb 2017
    Hamburg
    31
    Thanks, again, Donkuz
    I'm getting better
    For the sound icon / network icon and Safely remove hardware and eject media icon, would it be possible to replace the color ?
    They were white, now they are black
    As I said in a previous post, i have an old PDF with a lot of locations but they are not the same anymore, for Windows 10 ( attached image )
    Can I found something like this pdf, but with the Windows 10 locations ??
  6. #18
    Donkuz is offline
    Pro Customizer
    Nov 2017
    Australia
    55
    935
    6 Thread(s)
    I'm getting better
    OK, Sorry for the wait Mate, All those icons can be changed but you won't find them in WSB. I will send you the location in a PM Theres a bit to it. OK now The PDF from Dave Senior is a bit outta date but it has all the locations and gives you a bit of an Idea where to look, basicly all the directions are correct you just have to work out where they for Light and Dark Mode, you have 3 Areas now to look for Light, Dark and the Default Settings I work on the Light Mode first because anything you cant find in the light mode you will find in the Default settings because in both Dark and Light mode they Inherit property's from the default settings, Its a little bit confusing at first but I can help you anytime just send me a pm if you get stuck.
    It would be really Cool to have a new PDF Guide, one thats made for 1903+ Would be Invaluble and save a lot of time. Anyway I hope this explans it a bit better for you but Im really not aware of an upto date Guide I wish there where. Hmm maybe I will send Dave a PM if his still around and I can find him
  1. Taskbar Issue
    By CsqU4r3d in forum Windows 10 Theme Help and Support
    Last Post: 02-23-2019, 04:04 PM
  2. Taskbar Icon Right Click Bug
    By Nimbi in forum Theme Issues
    Last Post: 12-13-2014, 08:13 AM
  3. Taskbar icons issue
    By zefs in forum Taskbar & System Tray
    Last Post: 06-09-2014, 10:19 PM
  4. Taskbar (And Start Orb) Issue
    By LupinePredator in forum Taskbar
    Last Post: 03-03-2014, 02:07 AM
  5. Replies: 0
    Last Post: 04-10-2011, 06:25 PM
