August 23rd, 2020 08:20 PM #1
- Aug 2011
- Atlanta, Georgia
- 1,577
- 280 Thread(s)
Sufferance Mega Theme Pack for Windows 1903 - 20H1
Mega Theme Pack
All Themes Updated for continuity
Original Themes By Gor
For Use Only on Windows 1903 thru 20H1
All Themes Included:
Sufferance Red
Sufferance Blue
Sufferance Yellow
Sufferance Pink
New Color! Sufferance Orange
Themes Includes
start button
Gor - Original Theme Design
J4M3SX019 - Windows 7 to 10 port
Some Tools You May Need
ONE
1.) Create a Restore Point
Ghostly theme no ghost Complete pack for Windows 10 19h1 19h2 20h1 20h2 21h1
By ミறѳѳղղįզվદ彡 in forum Themes by gsw953Replies: 5Last Post: February 17th, 2022, 05:56 PM -
Sufferance Yellow for Windows 10 1903 thru 20H1
By Dark Knight in forum Themes by Dark KnightReplies: 10Last Post: September 4th, 2020, 02:26 PM -
Sufferance Blue for Windows 10 1703 - 1903
By Dark Knight in forum Themes by Dark KnightReplies: 4Last Post: June 4th, 2019, 02:57 PM -
Sufferance Windows 8.1 Theme
By Lamia in forum gor17981 Windows 8 ThemesReplies: 22Last Post: May 22nd, 2015, 07:50 PM -
Sufferance: Red Windows 8.1 Theme
By Lamia in forum gor17981 Windows 8 ThemesReplies: 21Last Post: August 21st, 2014, 09:25 PM
Hi @shemhamforash I don't have issue to set titelbar text color did you saved your settings after changes ?
Post Your Windows 11...
