Results 7 to 12 of 13
August 25th, 2020 09:31 PM #1
- 5,503
Windows 10 20h2++ The beginning of the end for Control Panel (How to open old System)
Windows 10 20h2++
Microsoft has started testing the removal of the venerable System control panel on Windows 10
and instead redirecting users to the modern About page.
The System control panel allows users to get a brief overview of the operating system version
network configuration and installed hardware.
Commonly used to determine the Windows 10 version
computer name, and workgroup, and installed CPU and memory
the System control panel has been an often-used tool since it was introduced in Windows NT 3.51 and Windows 95.
As spotted by WindowsLatest, in Windows 10 Insider build 20161
Microsoft is rolling out a change that redirects users to the Windows 10 About page
when trying to open the System control panel.
New and improved Windows 10 About page
As part of this change, Microsoft has also added the ability to copy data from the About page
and provide information about your active security protections.
The beginning of the end for Control Panel?
In Windows 8, Microsoft introduced the new modern Settings feature
and moved much of the operating system's configuration and options to it.
At the same time, they kept the Control Panel in place
and continued to use it for many configuration options.
The different appearance between the Windows 10 Settings and Control Panel
has always led to a disjointed feel to configuring Windows 10.
The System control panel redirection appears to be beginning of a plan to retire the old Windows Control Panel
and move all configuration options and information into the modern Windows 10 Settings pages.
"There will be more improvements coming that will further bring Settings closer to Control Panel.
If you rely on settings that only exist in Control Panel today, please file feedback
and let us know what those settings are," Brandon LeBlanc, Senior Program Manager
of the Windows Insider Program, shared in a blog post.
The removal of Control Panel and its migrations of settings to the modern Windows 10 Settings
is a good thing.While it always sad to see something used so often go away, it has always felt like it did not belong in Windows 10.
and now sorry because i dont have free time for all responds and all other works
here is my tutorial
you can use old control panel on the w10 20h2 19042
just open control panel and put to the command bar
Control Panel\System and Security\System
and press enter
this open your old system info
and i think this be can updated in the new version of Start is back
for really skilled this (New redirect) can be replaced manually in the StartIsBackCfg.exe with Restorator .etc
but i am not owner of StartIsBack and i dont have permission for sharing this step with you sorry
in this time if you like w10 20h2 you can use this my step
click on System (copy address) and create a new Shortcut
paste your new shortcut where you need
hello friends
if you like fast open your old system info
you can put the new shortcut to the Quick access or to the Explorer
Right click on File Explorer/System
Windows 10 Control Panel !!
By RDS SHOVON 97 in forum General Windows 10 CustomizationReplies: 3Last Post: September 21st, 2022, 11:48 PM -
Can you change Control Panel Applets texture/colour on Windows 10?
By MatthewPatel in forum Windows 10 Theme Help and SupportReplies: 1Last Post: May 12th, 2019, 03:35 PM -
Pin Control Panel To Taskbar To Quickly Access Control Panel In Windows 8
By razorsedge in forum Help and SupportReplies: 0Last Post: December 8th, 2012, 03:44 AM -
WSCC - Windows System Control Center silent installer
By razorsedge in forum Tweaking and TuningReplies: 4Last Post: November 1st, 2011, 07:22 AM -
Control Panel
By vceu in forum Theme Building QuestionsReplies: 0Last Post: April 1st, 2011, 04:50 PM
