Thread: Blade Ultimate edition for Windows 10 2004 20h1
    ミறѳѳղղįզվદ彡 is offline
    Co-Admin♀ Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young
    🌸In the Future🌸
    5,510
    Package Favorite Blade Ultimate edition for Windows 10 2004 20h1
    Mr GRiM
    Blade Theme for Windows 10
    7tsp Blade Ultimate Icon Pack
    The Ultimate Icon Pack for Windows 10
    This Icon Pack Includes Special Icons and files as
    Explorer.exe , Shell32.dll , timedate.cpl
    Windows media player skin
    Task Manager .etc
    Additional Theme Extras
    7tsp Blade Ultimate Icon Pack for Windows 10
    ported for Windows 10 2004 20h1 by
    Moonnique®
    7tsp Ultimate Icon Pack for Windows 10 2004 20h1
    Please do not run this Icon Pack on w7 w8 w10 TH2-RS5!
    Windows 10 19h1 1903 Windows 10 19h2 1909
    This Icon Pack is created only for Windows 10
    19041 2004 20h1 with new .mun files
    Icon Pack has been ResRebuilded
    I have noticed 7tsp packs have been getting bigger and bigger in size.
    This is because some res editors leave old data inside the res files after modifying and saving them.
    This tool rebuilds all res files from a resources folder so they are clean of any rest data
    Windows 10 20h1 2004 OS build 19041
    Important INFO for Icon Pack Makers/Users more info here
    https://virtualcustoms.net/Windows-10-20h1-2004-OS-build-19041-Important-INFO-for-Icon-Pack-Makers-Users
    7tsp Blade Icon Pack
    Apply
    Install an
    Select the
    Copy a
    I
    nstallation:
    Open up 7TSP & click Add a Custom Pack & select the icon pack you want to install.
    Click on Start Patching.
    By default 7TSP will create a restore point & install the icon pack.
    Once installation is done reboot & you're done.
  1. Poison Red v2 Ultimate edition for Windows 10 2004 20h1
    By ミறѳѳղղįզվદ彡 in forum Themes by Mr GRiM
    Last Post: September 5th, 2021, 10:00 PM
  2. HUD Apocalypse Ultimate edition for Windows 10 2004 20h1
    Last Post: August 14th, 2021, 10:36 PM
  3. Poison Red Ultimate edition for Windows 10 2004 20h1
    Last Post: April 13th, 2021, 07:53 PM
  4. H20 Ultimate edition for Windows 10 2004 20h1
    Last Post: November 7th, 2020, 04:21 PM
  5. Rockstar Red Ultimate edition for Windows 10 2004 20h1
    By ミறѳѳղղįզվદ彡 in forum Moonnique's Ported Themes
    Last Post: August 28th, 2020, 08:11 PM
