Page 1 of 2 12 LastLast
Results 1 to 6 of 8
Thread: HUD Launch Ultimate edition for Windows 10 2004 20h1 Share
    றѳѳղղįqվદ® is offline
    Ʀεαℓ Ƙɳσωℓεɖɠε Ɲεѵεг Đเε!
    Moon
    24
    3,578
    Package Favorite HUD Launch Ultimate edition for Windows 10 2004 20h1
    Ultimate edition
    HUD Launch Theme for Windows 10
    7tsp HUD Launch Ultimate Icon Pack
    7tsp HUD Launch MUI Side Images
    Ultimate Icon Pack for Windows 10
    Includes 62 .res files
    This Icon Pack Includes Special Icons and files as
    Explorer.exe , Shell32.dll , timedate.cpl
    Windows media player skin
    Task Manager .etc
    7tsp HUD Launch Icon Pack for Windows 10
    ported for Windows 10 2004 20h1 by
    Moonnique®
    7tsp Ultimate Icon Pack for Windows 10 2004 20h1
    Please do not run this Icon Pack on w7 w8 w10 TH2-RS5!
    Windows 10 19h1 1903 Windows 10 19h2 1909
    This Icon Pack is created only for Windows 10
    19041 2004 20h1 with new .mun files
    Icon Pack has been ResRebuilded
    I have noticed 7tsp packs have been getting bigger and bigger in size.
    This is because some res editors leave old data inside the res files after modifying and saving them.
    This tool rebuilds all res files from a resources folder so they are clean of any rest data
    Windows 10 20h1 2004 OS build 19041
    Important INFO for Icon Pack Makers/Users more info here
    Task Manager .etc
    MUI Side Images for Windows 10 2004 20h1
    HUD Launch MUI Side Images by gor17981
    Additional Theme Extras
    AIMP 3 Skin thanks to Gor
    WINRAR Skin thanks to Gor
    I
    nstallation:
    Open up 7TSP & click Add a Custom Pack & select the icon pack you want to install.
    Click on Start Patching.
    By default 7TSP will create a restore point & install the icon pack.
    Once installation is done reboot & you're done
    poweredbyostx is offline
    Elite
    Nov 2012
    Banja Luka
    24
    1,023
    353 Thread(s)
    One of the coolest theme from HUD series in my opnion, thanks for share.
    pinkfloyder is offline
    Skilled
    Jun 2011
    103
    3 Thread(s)
    Looks absolutely fantastic. Many many thanks for all of your hard work guys!!!
    viruz02 is offline
    May 2019
    Philippines
    12
    need help, how can i fix start menu in program files the text is dark i cant read it.. does anyone know..
    Elite
    Nov 2012
    Banja Luka
    24
    1,023
    353 Thread(s)
    Quote Originally Posted by viruz02 View Post
    Please, it would be great from you to provide a screenshot of your issue.
    Or you can make a thread and post your issue with the theme
    viruz02 is offline
    May 2019
    Philippines
    12
    Quote Originally Posted by poweredbyostx View Post
    i try to upload a screenshot but its not working nothing happen.. when i click start menu and and click programs i can only see the icon the text is in dark..
  1. HUD Apocalypse Ultimate edition for Windows 10 2004 20h1
    By றѳѳղղįqվદ® in forum Themes by Mr GRiM
    Last Post: 3 Weeks Ago, 08:48 PM
  2. Poison Red v2 Ultimate edition for Windows 10 2004 20h1
    Last Post: 3 Weeks Ago, 08:44 PM
  3. H20 Ultimate edition for Windows 10 2004 20h1
    Last Post: 4 Weeks Ago, 08:57 PM
  4. Poison Red Ultimate edition for Windows 10 2004 20h1
    Last Post: 4 Weeks Ago, 02:01 AM
  5. Rockstar Red Ultimate edition for Windows 10 2004 20h1
    By றѳѳղղįqվદ® in forum Moonnique's Ported Themes
    Last Post: 08-28-2020, 08:11 PM
