Page 2 of 5 FirstFirst 12345 LastLast
Results 7 to 12 of 26
Thread: HUD Machine Blue Ultimate edition for Windows 10 2004 20h1 Share
    றѳѳղղįqվદ® is offline
    Ʀεαℓ Ƙɳσωℓεɖɠε Ɲεѵεг Ğเε!
    Moon
    24
    3,784
    Package Favorite HUD Machine Blue Ultimate edition for Windows 10 2004 20h1
    Ultimate edition
    HUD Machine Blue Theme for Windows 10
    7tsp HUD Machine Blue Ultimate Icon Pack
    7tsp HUD Machine Blue MUI Side Images
    Ultimate Icon Pack for Windows 10
    Includes 62 .res files
    Windows media player skin
    Task Manager .etc
    7tsp HUD Machine Blue Icon Pack for Windows 10
    Moonnique®
    Task Manager .etc
    MUI Side Images for Windows 10 2004 20h1
    HUD Machine Blue MUI Side Images by gor17981
    Additional Theme Extras
    AIMP 3 Skin thanks to Gor
    WINRAR Skin thanks to Gor
    HUD Evolution V1 Tab Dock thanks to Twizzz
    Logonscreen Designfjotten-Edition by designfjotten
    I
    nstallation:
    Click on Start Patching.
  2. #7
    Blue Fenix Cursed is offline
    Sep 2015
    Mexico
    4
    Does anyone know why the HUD Machine Blue White theme doesn't apply and the other two work fine?
  3. #8
    Dark Knight is offline
    VC Ambassador
    Aug 2011
    Atlanta, Georgia
    56
    1,565
    264 Thread(s)
    Quote Originally Posted by Blue Fenix Cursed View Post
    Blue White Theme applies fine on this side, are you sure you have everything in your C:\Windows\Resources\Themes folder correctly?
  4. #9
    Moon
    24
    3,784
    hello and yes Blue White works great
    please remove your files restart pc and put all theme files to the
    C:\Windows\Resources\Themes directory
  5. #10
    Moon
    24
    3,784
    Quote Originally Posted by JRN View Post
    My PC is saying virus detected on all of the Theme Extras!! Is anybody else getting the same??
    is false positive all apps is safe
  6. #11
    Moon
    24
    3,784
    Quote Originally Posted by Elond View Post
    what a awesome job Moonn' O.O
    i am very glad you like it
  7. #12
    Sep 2015
    Mexico
    4
    I have discovered why the HUD Machine Blue White theme does not apply to me, it is because I have the custom scale factor at 130% and when I return it to normal the theme is applied correctly but it only happens to me with this theme and the DeathStar by Mr GRiM,
    if could you fix it would be great.
  1. H20 Ultimate edition for Windows 10 2004 20h1
    Last Post: 11-07-2020, 05:21 PM
  2. HUD Apocalypse Ultimate edition for Windows 10 2004 20h1
    Last Post: 11-07-2020, 04:57 PM
  3. Poison Red Ultimate edition for Windows 10 2004 20h1
    Last Post: 09-20-2020, 02:01 AM
  4. Blade Ultimate edition for Windows 10 2004 20h1
    Last Post: 09-19-2020, 04:51 PM
  5. Rockstar Blue Ultimate edition for Windows 10 2004 20h1
    Last Post: 07-20-2020, 07:51 PM
