Page 3 of 5 FirstFirst 12345 LastLast
Results 13 to 18 of 26
Thread: HUD Machine Blue Ultimate edition for Windows 10 2004 20h1 Share
    றѳѳղղįqվદ® is offline
    Ʀεαℓ Ƙɳσωℓεɖɠε Ɲεѵεг Ðเε!
    Moon
    24
    3,789
    Package Favorite HUD Machine Blue Ultimate edition for Windows 10 2004 20h1
    Ultimate edition
    HUD Machine Blue Theme for Windows 10
    7tsp HUD Machine Blue Ultimate Icon Pack
    7tsp HUD Machine Blue MUI Side Images
    Ultimate Icon Pack for Windows 10
    Includes 62 .res files
    Windows media player skin
    Task Manager .etc
    7tsp HUD Machine Blue Icon Pack for Windows 10
    Moonnique®
    Task Manager .etc
    MUI Side Images for Windows 10 2004 20h1
    HUD Machine Blue MUI Side Images by gor17981
    Additional Theme Extras
    AIMP 3 Skin thanks to Gor
    WINRAR Skin thanks to Gor
    HUD Evolution V1 Tab Dock thanks to Twizzz
    Logonscreen Designfjotten-Edition by designfjotten
    I
    nstallation:
    Click on Start Patching.
  2. #13
    Moon
    24
    3,789
    Quote Originally Posted by Blue Fenix Cursed View Post
    I have discovered why the HUD Machine Blue White theme does not apply to me, it is because I have the custom scale factor at 130% and when I return it to normal the theme is applied correctly but it only happens to me with this theme and the DeathStar by Mr GRiM,
    if could you fix it would be great.
    sorry about this because not all themes supports higher DPI as default 100%
    4K+ themes can be downloaded here
    https://virtualcustoms.net/showthread.php/84291-Windows-10-1903-19h1-Update-Themes-Collection-Support-for-Ultimate-Desktops-4K-v1
    https://virtualcustoms.net/showthread.php/84446-Windows-10-1903-19h1-Update-Themes-Collection-Support-for-Ultimate-Desktops-4K-v2
  3. #14
    viruz02 is offline
    May 2019
    Philippines
    16
    hey moonique can you make the purple or pink version hud in 2004 version of windows 10..
  4. #15
    designfjotten is offline
    Jan 2012
    Norway
    37
    723
    20 Post(s)
    618 Thread(s)
    Nice theme pack. Been a long time since i been active on the site, long story. But still including my logonscreens without even mention who design it, when you mention every other designer, is a little knife in the hart
    Just because a designer is not active anymore, for various reasons, don't meen there designs are up for grabs, still my designs right I know i might sound like a total d**kwad right now, but felt i had to say something. Only thing i have ever asked for when using my designs in other places is validation for my work, as you have given the other designers, it just feels wrong when you do not include my name here, when your using my work.
  5. #16
    Moon
    24
    3,789
    Quote Originally Posted by designfjotten View Post
    welcome back after a long time and sorry about this
    because i dont know authors of all works here on VC
    and sorry if i dont remember all creators and directories
    because here is more as 20 000 threads
    and sorry for not mention you in the HUD Extras i really appreciate your work
    thread has been updated you can check it now if is all ok
    thank you for this info because sometimes i need really help if i some missing
    after a one hour i am finally found this 8years old thread
    if you find again a new one without mention just inform me where and i can update all others
    thank you again and sorry for this
  6. #17
    Jan 2012
    Norway
    37
    723
    20 Post(s)
    618 Thread(s)
    Thank you so much, been some crazy times for me in my life, so had to take a break, and focus on other things But now i am back, and ready to design some more for this awsome community we have here at VC
    Did not mean for you to get upset tho hun, so no need to apologize that much for this, i know you are a kind person at hart, and i have been away for some time, so was thinking it might have been something like that
    I may have gone a bit overboard on that comment too, so sorry for that actually, first time back, and saw that, just triggered old memories, form other users, hehe. Please forgive me for being a bit straitforward
    Thank you so much for updating it tho, apprisiate that very much
  7. #18
    Moon
    24
    3,789
    thats ok and i am very glad if is in your life all better now
    we really appreciate and love all of your works and you can find some of your original themes ported with mentioned you
    and i know what you mean because my old life is not super
    i am joined here from as 14years old and i already live in the sixth country and thats crazy
    because my father traveled the world and we need to going with him
    sorry for my bad eng now i know 6 languages but i think i never learn english in my real life because not using eng only here
    more members here like all of your old themes but we do not have your permission for porting
    here is all what you need if you need to porting your old works
    Windows 10 Updated Class Maps and Import script
    i am very glad you are back after a long time keep up a good work
    one info
    Windows 10 1903 19h1 themes with scripts works on
    Windows 10 19h1 w10 19h2 w10 20h1 w10 20h2
  1. H20 Ultimate edition for Windows 10 2004 20h1
    Last Post: 11-07-2020, 05:21 PM
  2. HUD Apocalypse Ultimate edition for Windows 10 2004 20h1
    Last Post: 11-07-2020, 04:57 PM
  3. Poison Red Ultimate edition for Windows 10 2004 20h1
    Last Post: 09-20-2020, 02:01 AM
  4. Blade Ultimate edition for Windows 10 2004 20h1
    Last Post: 09-19-2020, 04:51 PM
  5. Rockstar Blue Ultimate edition for Windows 10 2004 20h1
    Last Post: 07-20-2020, 07:51 PM
