Results 19 to 24 of 34
Thread: Cryogenix X
    devillnside is offline
    Elite
    Aug 2012
    Dhaka, Bangladesh
    1,458
    1 Post(s)
    51 Thread(s)
    Cryogenix X
    Cryogenix X
    Theme for Windows 10 2004 20H1, 1909 19H2 & 1903 19H1 Builds
    Lockscreen:
    Updated to version 1.1
    Screenshots updated for new version
    11.12.20:
    Changelog:
    Major overhaul & clean up of the start menu.
    Tweaked the taskbar.
    Tweaked the taskband task item buttons.
    Tweaked system tray flyout header & footer images for those using classic volume controls.
    New dwm window bottom outer border.
    Cleaned up & tweaked the dwm window left, right & top outer borders.
    Major overhaul of explorer details pane.
    New explorer & control panel command modules.
    New branding image in control panel.
    Overhauled all combobox backgrounds across the theme.
    New spin buttons.
    Fixed calendar background.
    Fixed tooltip colours.
    Fixed unthemed toolbar buttons.
    New taskdialog secondary panel background.
    Tweaked & cleaned up wallpapers.
    How To:
    Y
    ou'll need your system patched with UXThemePatcher.
    UltraUXThemePatcher:
    StartIsBack:
    https://www.startisback.com/
    OldNewExplorer:
    C:\Windows\Resources\Themes
    Extras:
    Cryogenix Logon/Lockscreens in 1920x1080 & 2560x1440 resolutions.
    Cryogenix X v1.1.zip
    Last edited by devillnside; December 11th, 2020 at 12:01 AM. Reason: Updated theme to version 1.1
    D@rkside Of Aquarius™
  1. Cryogenix
    By devillnside in forum devillnside's Windows 7 Themes
    Last Post: October 16th, 2020, 06:07 PM
Tags for this Thread
