Page 4 of 5 FirstFirst 12345 LastLast
Results 19 to 24 of 30
Thread: Help to change a color Share
  1. #19
    Suvorov Vladimir is offline
    May 2017
    Germany
    12
    OK, all text. Good luck!
  2. #20
    Donkuz is offline
    Pro Customizer
    Nov 2017
    Australia
    55
    1,023
    11 Thread(s)
    Quote Originally Posted by Suvorov Vladimir View Post
    OK Mate, This is how Explorer in Dark and Light Mode I couldn't make it all Green without using some of the Light mode settings as you can see in the screenshots as they use some of the same locations, When you said Color all the text colors do you mean for Both Modes and do a total recolor with the Start menu and Control panel because that will take me faira while to go tru the whole theme, although It is possible to leave The Rest of Explorer in light mode so the Green is only visible in the top of Explorer and the menus like in the screenshot? Anyway I will leave it like this and wait untill I here from you again. I hope you like it Cheerz!
  3. #21
    bakiras is offline
    Nov 2020
    India
    16
    Quote Originally Posted by Donkuz View Post
    OK Mate, here you go.
    For the Highlight in the Dropdown menu Go to Both Light and Dark Mode settings in the tree and Locate Address,Breadcrumbs and search and select Combo Box and go to the Drop Down Text Area settings and change your Fill Color and text Color there in both The Light and Dark Mode Settings.
    OK For The Search Box Dropdown Background go to Address,Breadcrumbs and Search again in both Light and Dark Mode and Select SearchBox/ Areo / Normal /Active/BackGround and edit the image there for Inactive to and do it in Both the Light and Dark Mode Settings.
    OK For The Status Bar go to Both Light and Dark Mode Settings again and Go to Explorer and Shell and Select Explorer/Explorer Status Bar and change the fillcolor and text there and again do it in Both Light and Dark Mode Settings.
    OK Mate I hope this helps
    Cheerz!!
    Thanks a lot mate. Statusbar Color worked.
    Search Box Dropdown Background color change is not working but, it is fine. And I also find that every custom themes I downloaded from deviantart is also have this issue.
    Highlight in the Dropdown menu meant by this.
  4. #22
    Donkuz is offline
    Pro Customizer
    Nov 2017
    Australia
    55
    1,023
    11 Thread(s)
    Quote Originally Posted by bakiras View Post
    OK now I understand, For the Nav Panel Hover and selected text colors go to Both light and DarkMode Settings and select Explorer and Shell.
    >Explorer>Treeview>Tree Item you can change it there for Normal, Hot and Selected etc. Do this for Both Light and Dark Modes.
    OK So for the Items in the right side, again Do this for Both Light and Dark Mode. Go to Explorer and Shell again and >Explorer>ItemsView>ItemsView>Details> and you will find the settings there to change the Propertys, and Selected Text and Change the colors there.
    OK I hope this helps Sorry about the wait I saw this on my way to Bed LastNight and was to buggered to respond.
    Anyway Cheerz Bro, Have a Great day.
  5. #23
    bakiras is offline
    Nov 2020
    India
    16
    Help needed for change the Orange highlight color without changing the background color
  6. #24
    Donkuz is offline
    Pro Customizer
    Nov 2017
    Australia
    55
    1,023
    11 Thread(s)
    OK mate, Go to Lists Menus and tabs and select Context Menu in the list Select Popup Item and edit the Hot Image Then go to the Immersive context Menu and do the same also for the Dark Immersive context menu. The right click destop menu is the Context Menu and the Immersive menus are the right click Taskbar menu and the Dark Immersive Start menu. Anyway Let me know how you go this time. Goodluck!!!
  1. Replies: 3
    Last Post: 05-12-2020, 08:25 PM
  2. help Change Color
    By MrToxicCodes in forum Taskbar & System Tray
    Last Post: 07-20-2012, 12:30 AM
  3. How to change color
    By render in forum Fonts, colors and system metrics
    Last Post: 05-19-2011, 05:59 AM
  4. Change color
    By fa1993 in forum General Questions
    Last Post: 05-22-2010, 02:39 PM
  5. how change color this here ?
    By cu88 in forum Miscellaneous questions
    Last Post: 03-22-2010, 08:35 AM
