Page 3 of 3 FirstFirst 123
Results 13 to 18 of 18
Thread: JARVIS Ultimate edition for Windows 10 20h1 20h2 Share
    றѳѳղղįqվદ® is offline
    Ʀεαℓ Ƙɳσωℓεɖɠε Ɲεѵεг Đเε!
    Moon
    24
    3,789
    Package Favorite JARVIS Ultimate edition for Windows 10 20h1 20h2
    Theme for Windows 7
    Uploaded by [Only registered and activated users can see links. ]
    Theme for Windows 8 8.1
    Ported by [Only registered and activated users can see links. ]
    Theme for Windows 10 Creators Update (version 1703)
    Theme for Windows 10 Fall Creators Update (version 1709)
    Ported by
    Mr GRiM
    Ultimate edition
    JARVIS Theme for Windows 10
    7tsp JARVIS Ultimate Icon Pack
    JARVIS Theme for WinRAR
    7tsp JARVIS Ultimate Icon Pack for Windows 10
    ported for Windows 10 20h1 20h2 by
    Moonnique®
    7tsp Ultimate Icon Pack for Windows 10 20h1 20h2
    19041 2004 20h1 and for 19042 2009 20h2
    with new .mun files
    I
    nstallation:
    Click on Start Patching.
    Once installation is done reboot & you're
    done
    Information
    Ultimate Icon Pack fixes
    Complete JARVIS Icon Pack includes
    explorer.exe Icon , 3D Objects Icon , OneDrive Icon
    Quick Access Icon , Pin and UnPin Icons
    Action Center Icon , Context Menu Icons .etc
    with new .mun files
    Information
  2. #13
    Moon
    24
    3,789
    Quote Originally Posted by Donkuz View Post
    Yep you sure can all mine are working fine with it bro.
    Quote Originally Posted by devillnside View Post
    so you can run 20h1 themes on 20h2 as is??? or are further adjustments necessary?
    hello Friends
    one Info for Icon Pack Users
    updated 7tsp Icon Packs with description
    7tsp Icon Pack for w10 20h1 2004 19041 works great on
    Windows 10 2009 20h2 19042 because 20h2 is only the feature update
    Windows 10 20h1 and 20h2 works on the same base 19041.1
    and using the same System files
    Themes for Windows 10 1903 19h1 works on
    W
    indows 10 1903 19h1 18362
    Windows 10 1909 19h2 18363
    Windows 10 2004 20h1 19041
    because works on the same base
    you can run 19h1 themes on 20h2 syste
    m
    only the 7tsp Icon Packs need be updated
    bacuse using more of the new Icons
    and Icon Locations with the new subfolders (IMAGE) .et
    c
  3. #14
    Nimbi is offline
    Moderator
    Aug 2014
    Coolidge, AZ, USA
    1,926
    2 Post(s)
    60 Thread(s)
    Nice, sadly I couldn't get 7tsp to run. Kept hanging on Shutting Down the Taskbar. Not to big an issue for me though as I'm actually more partial to IconPackager now anyways xD
  4. #15
    Moon
    24
    3,789
    Quote Originally Posted by Nimbi View Post
    i think Icon Packager know to replace only 20 default system icons
    dont know if you can replace 3D Objects folder included only in the w10 with it .etc
    with 7tsp you can replace all what you need in the
    C:\Windows\windir\explorer.exe , regedit.exe ...
    C:\Program Files\installed program icons and splash screens
    C:\Windows\en-US\.mui files
    C:\Windows\System32\en-US\.mui files
    C:\Windows\System32\every file in this directory what you need to replace
    C:\Windows\SysWOW64\every file in this directory what you need to replace
    C:\Windows\SystemResources\every file in this directory what you need to replace
    7tsp know to patch system and allowing using 3rd party themes without using UltraUXTheme patcher
    7tsp know to replace any file what you need .dll .exe .cpl .mui .mun ...
    7tsp know installing custom theme
    Icon packs and MUI side images
    7tsp know to replace taskmanager and taskmanager colors
    7tsp know to replace CopyAnimation color
    and many many many other things as system sounds ...
    if you have problem with taskbar before patching
    just go to the Control Panel\Programs\Turn Windows features on or off and allow .NET Framework
    if your problem persist update your VC Redist here is the last November 2020 update All in one
  5. #16
    Nimbi is offline
    Moderator
    Aug 2014
    Coolidge, AZ, USA
    1,926
    2 Post(s)
    60 Thread(s)
    Good to know, I'll probably end up trying that later. Fr now though the main reason I like IconPackager is because it doesn't corrupt my icon cache when my system updates unlike 7tsp. And my system doesn't let me install any of my programs if I disabled automatic updates so clearly turning off updates is a major red flag for me.
    I use a lot of Metro Aps since I have XBox Game Pass Ultimate and that's one reason as to why turning off updates tends to screw me.
    Unfortunately I've had issues before with 7tsp skipping restores due to the backed up files being older than the patched files. Sometimes it even updates them itself during the patch and bricks the backup entirely.
    For now IconPackager is simply the safest option I have for my PC. And since I only recently got my Windows install fixed I'm not too keen to start having problems with it again.
  6. #17
    Moon
    24
    3,789
    IconPackager not replace this Icons after Windows update because
    IconPackager know to replace only some of the icons in the C:\Windows\System32\imageres.dll
    not in the C:\Windows\SystemResources\imageres.dll.mun
    Why is this icons never changed after Windows update?
    because imageres.dll works only on the same default base
    imageres.dll Windows 10 19h1 19h2 (version 18362.1)
    imageres.dll Windows 10 20h1 20h2 (version 19041.1)
    you can patch imageres.dll.mun with 7tsp and after windows update this icons never been changed again
    only some system files have been updated again and again after windows update
    specially the shell32.dll.mun , ExplorerFrame.dll , explorer.exe , notepad.exe.mun , taskmgr.exe.mun ...
    because windows update change your system files
    and upgrade some apps and functions on the higher stable version
  7. #18
    Moon
    24
    3,789
    download Icon Pack what you like
    unzip this Icon Pack with 7zip
    if you like only imageres.dll.mun.res
    just remove all other .res files from the custom Icon Pack
    and zip this Icon pack back with 7zip
    run 7tsp GUI add this pack and click on start patching
  1. Poison Red v2 Ultimate edition for Windows 10 2004 20h1
    Last Post: 11-14-2020, 10:28 PM
  2. H20 Ultimate edition for Windows 10 2004 20h1
    Last Post: 11-07-2020, 05:21 PM
  3. Poison Red Ultimate edition for Windows 10 2004 20h1
    Last Post: 09-20-2020, 02:01 AM
  4. Blade Ultimate edition for Windows 10 2004 20h1
    Last Post: 09-19-2020, 04:51 PM
  5. Rockstar Red Ultimate edition for Windows 10 2004 20h1
    Last Post: 08-28-2020, 08:11 PM
