Thread: Templaero Revamped
December 3rd, 2020 03:50 AM #1
Templaero Revamped
Templaero Revamped
Theme for Windows 10 1903-2009 Builds
How To:
UltraUXThemePatcher:
StartIsBack:
https://www.startisback.com/
OldNewExplorer:
C:\Windows\Resources\Themes
Important:
If you want the start menu & taskbar to look like it does in the screenshots then check the 'Start is Back Settings' folder for screenshots of settings in SiB
specific to this theme.
This theme has a lot of transparency so for it to look the way it should you will need to use 'Aero Glass' for Windows 10.
Aero Glass GUI:
https://mega.nz/file/jIhEyawA#UUX_cO...DebvT0C3XpXm4w
This is the free version of Aero Glass with a GUI included for easy configuration.
THIS WILL PUT AN AERO GLASS WATERMARK ON YOUR DESKTOP WHEN IT IS ACTIVE.
Extract the 'AeroGlass' folder to the root of your system drive & run the AeroGlassGUI.exe file inside as administrator.
The settings for the program are includedin screenshots inside 'Aero Glass GUI Settings' folder.
Extras:
Templaero Logon/Lockscreens in 1920x1080 & 2560x1440 resolutions.
Big thanks to Moonnique for the tip on how to change the default round start menu user pic frame.
Credits for the wallpaper goes to its original author.
Templaero Revamped.zip
Primal Red Revamped
By devillnside in forum Themes by devillnsideReplies: 6Last Post: August 16th, 2018, 02:38 AM -
Primal Blue Revamped
By devillnside in forum Themes by devillnsideReplies: 8Last Post: August 11th, 2018, 04:34 PM -
Cimmerian XRS2 Revamped
By devillnside in forum Themes by devillnsideReplies: 12Last Post: October 8th, 2017, 03:13 PM -
Templaero VS
By devillnside in forum devillnside's Windows 7 ThemesReplies: 0Last Post: September 19th, 2016, 10:44 AM -
Templaero XS Theme for Windows 10 Anniversary Update AKA RS1
By devillnside in forum Themes by devillnsideReplies: 6Last Post: August 28th, 2016, 01:16 AM
Modern UWP applications use XAML code and Fluent Design System for their appearance.
How do i change these...
