Page 1 of 2 12 LastLast
Results 1 to 6 of 7
Thread: HUD Machine Aqua Ultimate edition for Windows 10 20h1 20h2 21h1 Share
    றѳѳղղįqվદ® is offline
    💜진정한 지식은💜💜결코 죽지 않는다💜
    💜In Your Heart💜
    25
    3,975
    Package Favorite HUD Machine Aqua Ultimate edition for Windows 10 20h1 20h2 21h1
    Ultimate edition
    HUD Machine Aqua Theme for Windows 10
    7tsp HUD Machine Aqua Icon Pack
    7tsp HUD Machine Aqua Icon Pack for Windows 10
    ported for Windows 10 20h1 20h2 21h1 by Moonnique®
    7tsp Icon Pack for Windows 10 20h1 20h2 21h1
    19041 2004 20h1 for 19042 2009 20h2
    and for Windows 10 21h1
    with new .mun files
    Click on Start Patching.
    with new .mun files
    viruz02 is offline
    May 2019
    Philippines
    22
    thanks for this cool themes im using this now..
    💜In Your Heart💜
    25
    3,975
    Quote Originally Posted by viruz02 View Post
    viruz02 is offline
    May 2019
    Philippines
    22
    hi i was using windows 10 2004 19041.450 and im using these cool themes but i only have one problem the system transparency works when you set it but everytime i restart my computer system transparency is gone i need to set it again.. i also try to format my computer to version 20H2 19042.867 same problem everything works except on system transparency.. i wonder what i do wrong..
    💜In Your Heart💜
    25
    3,975
    hello and remove systemtransparency.ini file saved in the C:\Users\*Your UserName*\Documents directory
    open SystemTransparency.exe set what transparent effect you like
    click on (Startup) to add this program to startup
    zbigniew59 is offline
    Nov 2013
    sweden
    54
    Or, edit the systemtransparency.ini file manually
    It works for me.
  1. HUD Machine Corps Ultimate edition for Windows 10 20h1 20h2
    Last Post: 3 Weeks Ago, 02:33 AM
  2. HUD Machine BlueWhite Ultimate edition for Windows 10 20h1 20h2
    Last Post: 03-08-2021, 10:42 PM
  3. HUD Machine Pink Ultimate edition for Windows 10 20h1 20h2 21h1
    Last Post: 02-21-2021, 04:38 PM
  4. HUD Machine Purple Ultimate edition for Windows 10 20h1 20h2
    Last Post: 02-09-2021, 02:49 PM
  5. HUD Machine Slate Ultimate edition for Windows 10 20h1 20h2
    Last Post: 02-09-2021, 12:30 PM
