Results 1 to 2 of 2
Thread: Obsidian theme by gsw953 for w10 19h1 19h2 20h1 20h2 21h1
    ミறѳѳղղįզվદ彡 is offline
    🌸In the Future🌸
    5,510
    Package Favorite Obsidian theme by gsw953 for w10 19h1 19h2 20h1 20h2 21h1
    Here is 2 versions of Obsidian theme
    theme for Windows 10 19h1 19h2 20h1 20h2 21h1
    and the second is a more minimal version
    no Address bar or Command bar and top Details pane
  1. Nvidia theme for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: June 1st, 2021, 09:18 PM
  2. Meld 2 Theme for Windows 10 19h1 19h2 20h1 20h2 21h1
    By ミறѳѳղղįզվદ彡 in forum Themes by gsw953
    Last Post: April 9th, 2021, 09:19 PM
  3. Version 2 Theme for Windows 10 19h1 19h2 20h1 20h2 21h1
    Last Post: April 1st, 2021, 01:19 PM
  4. Broken theme by gsw953 for w10 19h1 19h2 20h1 20h2 21h1
    Last Post: March 24th, 2021, 01:42 AM
  5. Consolidated theme by gsw953 for w10 19h1 19h2 20h1 20h2 21h1
    Last Post: March 23rd, 2021, 11:08 PM
