Thread: aero frame extender
March 26th, 2021 01:13 AM #1
- Nov 2019
- uk
- 27
- 0 Thread(s)
aero frame extender
<windows 1909 compatible
This is a script I wrote in AutoIT3, will extend the reflection image from HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Dwm\
REG_SZ CustomThemeReflection
I hope it may be of some use to any of you...
* issue where it's extending into some unwanted areas like drag and drop images. * Will look at later.
https://www.deviantart.com/mattybw0y
Code:#cs ---------------------------------------------------------------------------- AutoIt Version: 3.3.14.5 Author: sPksNinj Script Function: Date: 21.03.2021 #ce ---------------------------------------------------------------------------- ; Script Start #include <GUIConstants.au3> #include <WindowsConstants.au3> #include <WinAPI.au3> #include <Process.au3> #include <Misc.au3> Global $hDLL, $hWinEventProc, $hHook Global $Struct = DllStructCreate("int cxLeftWidth;int cxRightWidth;int cyTopHeight;int cyBottomHeight;") Global $sStruct = DllStructCreate("dword;int;ptr;int") $hDLL = DllOpen("User32.dll") $hWinEventProc = DllCallbackRegister("_WinEventProc", "none", "hwnd;int;hwnd;long;long;int;int") If Not @error Then OnAutoItExitRegister("OnAutoItExit") Else MsgBox(16 + 262144, "Error", "DllCallbackRegister(_WinEventProc) did not succeed.") Exit EndIf $hHook = _SetWinEventHook($hDLL) If @error Then MsgBox(16 + 262144, "Error", "_SetWinEventHook() did not succeed.") Exit EndIf While 1 Sleep(10) WEnd Func _WinEventProc($hHook, $iEvent, $hWnd, $idObject, $idChild, $iEventThread, $iEventTime) Local $PID = WinGetProcess($hWnd), $sEventProcName = _ProcessGetName($PID) if($iEvent = 0x8000) Then _DwmEnableBlurBehindWindow($hWnd) EndIf EndFunc ;==>_WinEventProc Func _DwmEnableBlurBehindWindow($hWnd) Const $DWM_BB_ENABLE = 0x00000001 DllStructSetData($sStruct, 1, $DWM_BB_ENABLE) DllStructSetData($sStruct, 2, "1") DllStructSetData($sStruct, 4, "1") GUISetBkColor(0x000000); Must be here! $Ret = DllCall( "dwmapi.dll", "int", "DwmEnableBlurBehindWindow", "hwnd", $hWnd, "ptr", DllStructGetPtr($sStruct)) If @error Then Return 0 Else Return $Ret EndIf EndFunc ;==>_DwmEnableBlurBehindWindow Func _SetWinEventHook($hDLLUser32) Local $aRet Local Const $ACUNT = 0x8000 Local Const $WINEVENT_OUTOFCONTEXT = 0x0 Local Const $WINEVENT_SKIPOWNPROCESS = 0x2 If Not $hDLLUser32 Or $hDLLUser32 = -1 Then $hDLLUser32 = "User32.dll" $aRet = DllCall($hDLLUser32, "hwnd", "SetWinEventHook", _ "uint", $ACUNT , _ "uint", $ACUNT , _ "hwnd", 0, _ "ptr", DllCallbackGetPtr($hWinEventProc), _ "int", 0, _ "int", 0, _ "uint", BitOR($WINEVENT_OUTOFCONTEXT, $WINEVENT_SKIPOWNPROCESS)) If @error Then Return SetError(@error, 0, 0) Return $aRet[0] EndFunc ;==>_SetWinEventHook Func OnAutoItExit() If $hWinEventProc Then Beep(3000, 5) DllCallbackFree($hWinEventProc) EndIf If $hHook Then DllCall("User32.dll", "int", "UnhookWinEvent", "hwnd", $hHook) If $hDLL Then DllClose($hDLL) EndFunc ;==>OnAutoItExit
Right Click Extender
By wolfman.jam in forum ApplicationsReplies: 5Last Post: June 4th, 2023, 05:39 AM -
Picture Frame Logon and User Frame
By IcicleThief69 in forum Log On ScreensReplies: 3Last Post: August 27th, 2013, 06:24 PM -
Win7 Control Panel Extender (CP-X)
By Generator2013 in forum MiscellaneousReplies: 10Last Post: May 17th, 2010, 12:14 PM
hi yeah you can find the new wsb v2 and complete theme guide on here just use search feature also you might need a purchase key to use the new wsb v2
Windows 11 Dark Theme...
