Thread: Meld 2 Theme for Windows 10 19h1 19h2 20h1 20h2 21h1 Share
    றѳѳղղįqվદ® is offline
    💜진정한 지식은💜💜결코 죽지 않는다💜
    💜In Your Heart💜
    25
    4,002
    Package Favorite Meld 2 Theme for Windows 10 19h1 19h2 20h1 20h2 21h1
    Meld 2 theme for Windows 10
    Full Transparent theme for
    Windows 10 21H1 2103 OS Build 19043
    W
    indows 10 19H2 1909 OS Build 18363
    Here is a updated version of Meld
    Meld is a mixture of a black File Explorer into a light theme
    This should solve many black background or black on black text issues
    associated with dark themes but still give a cool black Explorer.
    [Only registered and activated users can see links. ]System Metrics included in the "Extras" folder and logout or reboot Install an
    [Only registered and activated users can see links. ]iPack of your choice to change the system icons (check the Theme Extras section above for a link to the icons in the preview)! Select the
    [Only registered and activated users can see links. ]Theme's Start Menu and Taskbar in the StartIsBack++ configuration. If it's not a visible option to select the theme's start menu, apply your custom theme first! Copy a
    [Only registered and activated users can see links. ]Start Orb from the "Theme" folder to a new location, rename it, then open the StartIsBack++ configuration, click Add... select the Start Orb and click Apply.
  1. Version 2 Theme for Windows 10 19h1 19h2 20h1 20h2 21h1
    By றѳѳղղįqվદ® in forum Themes by gsw953
    Last Post: 04-01-2021, 01:19 PM
  2. Project Light Theme for Windows 10 19h1 19h2 20h1 20h2 21h1
    Last Post: 03-30-2021, 01:56 PM
  3. Ghostly theme no ghost Complete pack for Windows 10 19h1 19h2 20h1 20h2 21h1
    Last Post: 03-29-2021, 11:00 PM
  4. Obsidian theme by gsw953 for w10 19h1 19h2 20h1 20h2 21h1
    Last Post: 03-27-2021, 03:21 PM
  5. Broken theme by gsw953 for w10 19h1 19h2 20h1 20h2 21h1
    Last Post: 03-24-2021, 01:42 AM
