June 2nd, 2021 05:17 AM #1
- Aug 2014
- Coolidge, AZ, USA
- 1,915
- 2 Post(s)
- 61 Thread(s)
Restore Missing New “Folder” to the Desktop Right-Click menu
When you right-click an empty area on the desktop, the “New” menu that appears may not contain the “Folder” entry. Also, when attempting to create a folder by clicking the “New Folder” toolbar button in a folder or by pressing the Ctrl + Shift + N keys, nothing may happen.
You cannot create a new folder if the “Folder” registry entries are missing. This post explains how to fix the problem.
Restore New “Folder” option to the right-click menu
You can restore the “Folder” entry in the “New” menu using the following procedure:
- Start the Registry Editor (regedit.exe)
- Navigate to the following location:HKEY_CLASSES_ROOT\Folder
- In the right-pane, double-click (default) and set its data to Folder
- Exit the Registry Editor.
- Log off and log back in.
You should now be able to create new folders via the right-click menu, Ctrl + Shift + N keystroke, or via File Explorer ribbon.
This tutorial is obtained from: Restore Missing New “Folder” to the Desktop Right-Click menu » WinhelponlineLast edited by Nimbi; June 2nd, 2021 at 05:20 AM.
Start menu missing Userpane class
By kamilmysz in forum Windows 8 Help & SuportReplies: 4Last Post: May 25th, 2018, 08:56 PM -
Help Right click menu color bug
By sonepaul in forum Theme IssuesReplies: 0Last Post: August 1st, 2014, 12:08 PM -
Right Click Menu (Not personalize menu)
By miketech in forum Lists, menus and tabsReplies: 4Last Post: May 26th, 2011, 06:29 AM -
Desktop Restore
By razorsedge in forum DesktopReplies: 0Last Post: August 4th, 2010, 06:21 AM -
Desktop right click menu problem
By X-ile in forum Lists, menus and tabsReplies: 2Last Post: April 23rd, 2010, 02:34 AM
Taskbar2 Taskbar2 is new StartAllBack (partially) recreated taskbar prototype. It's not a product and is for testing only. Task buttons: - Better: ungrouped icons are pixel-perfect if possible -...
TASKBAR2 ALPHA
