Results 1 to 4 of 4
Thread: Event Horizon Desaturated Ultimate for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2 Share
    றѳѳղղįqվદ® is offline
    💜진정한 지식은💜💜결코 죽지 않는다💜
    💜In Your Heart💜
    25
    4,172
    Package Favorite Event Horizon Desaturated Ultimate for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Theme Exclusive for Virtual Customs only thanks for all the requests guys
    I do not authorize this theme to be posted anywhere but Virtual Customs
    The Year 2040
    Deep Space research vessle the Event Horizon
    Launched to explore boundries of solar system
    She disappears without a trace
    Beyond the 8th planet neptune
    It's the worst space disaster on record...
    The Year 2047
    Event Horizon reappears
    after being gone for more then 7 years
    Where has she been......
    In space no one can hear you scream...
    Event Horizon Desaturated Version
    This is a special edition of this theme thanks to a tip from grimmer
    that a desaturated version would look good for this theme.
    Has new icons and dock skin, new gadgets
    and all other extras as well as some new walls
    Thanks for the suggestion Grim bud
    Remastered for the best quality and look possible.
    I have taken this theme and reworked it to be the best in my opinion
    hope you all enjoy it
    Event Horizon Desaturated Ultimate edition for Windows 10
    Windows 10 21H2 2009 OS Build 21390
    Event Horizon Desaturated Includes
    Custom start orb
    Custom explorerfame.dll buttons and images
    Custom navigation panel for shell32.dll
    Custom Imageres.dll Icons
    Custom Event Horizon all new sound pack
    Custom The Heavy Cursor pack
    Eurostile, Microgramma and Alexis Fonts
    7 Custom wallpapers
    Event Horizon Extras Pack Includes
    45+ Custom Dock icons
    Objectdock skin
    Event Horizon gadgets
    Custom Event Horizon shellbrd orb
    Custom Event Horizon genuine image for system.cpl
    Custom clock for timedate.cpl
    I would like to thank
    Mr Grim for all his help with this theme
    thanks much bud could not have done it without you
    [Only registered and activated users can see links. ] , [Only registered and activated users can see links. ]
    7tsp Razorsedge
    System Icon Pack
    ported for Windows 10
    19h1 - 21h2 by
    Moonnique®
    7tsp Razorsedge
    System MUI Side Images
    19h1 - 21h2 by
    Moonnique®
    Additional Extras
    Click on Start Patching.
    Robbo is offline
    Apr 2013
    U.K
    57
    430
    139 Thread(s)
    Many thanks [Only registered and activated users can see links. ]
    💜In Your Heart💜
    25
    4,172
    Information
    ok Friends
    thread has been complete updated
    added Complete Icon Pack for Windows 10 19h1 - 21h2
    MUI Side Images for Windows 10 19h1 - 21h2
    and all Icon Pack Additional Extras
    💜In Your Heart💜
    25
    4,172
    Quote Originally Posted by Robbo View Post
  1. Special Edition for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: 1 Week Ago, 08:35 PM
  2. AMD Experience the Revolution theme for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: 2 Weeks Ago, 07:59 AM
  3. The Colony theme for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: 2 Weeks Ago, 05:04 AM
  4. Castle theme for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: 3 Weeks Ago, 08:39 AM
  5. John Wick theme for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: 3 Weeks Ago, 08:45 PM
