Thread: Klingon theme for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2 Share
    றѳѳղղįqվદ® is offline
    💜진정한 지식은💜💜결코 죽지 않는다💜
    💜In Your Heart💜
    25
    4,222
    Package Favorite Klingon theme for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Klingon General Chang
    Have you not a shred of decency in you, Kirk?
    We come in peace, and you BLATANTLY DEFILE THAT PEACE!
    And for that, I shall blow you out of the stars!
    Remastered for the best quality and look possible
    I have taken this theme and reworked it to be the best in my opinion, hope you all enjoy it
    Windows 10 21H2 2009 OS Build 21390
    Custom Sound Pack
    Custom Cursors
    Explorer Frame Images
    Start button
    Image Res Icons
    Shell32 Images
    Custom Wallpapers
    Genuine Image
    Time Date Clocks
  1. Annihilation theme for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: 06-14-2021, 09:12 AM
  2. Event Horizon theme for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: 06-08-2021, 06:03 PM
  3. MS One Maximum Security One Red theme for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: 06-05-2021, 09:00 PM
  4. The Colony theme for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: 06-03-2021, 05:04 AM
  5. Castle theme for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: 06-02-2021, 08:39 AM
