Results 1 to 6 of 6
Thread: Event Horizon Blue Ultimate edition for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2 Share
    றѳѳղղįqվદ® is offline
    💜진정한 지식은💜💜결코 죽지 않는다💜
    💜In Your Heart💜
    25
    4,329
    Package Favorite Event Horizon Blue Ultimate edition for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Theme Exclusive for Virtual Customs only thanks for all the requests guys
    I do not authorize this theme to be posted anywhere but Virtual Customs
    The Year 2040
    Deep Space research vessle the Event Horizon
    Launched to explore boundries of solar system
    She disappears without a trace
    Beyond the 8th planet neptune
    It's the worst space disaster on record...
    The Year 2047
    Event Horizon reappears
    after being gone for more then 7 years
    Where has she been......
    In space no one can hear you scream...
    Windows 10 21H2 2009 OS Build 21390
    Event Horizon Theme Includes
    Custom start orb
    Custom explorerfame.dll buttons and images
    Custom navigation panel for shell32.dll
    Custom Imageres.dll Icons
    Custom Event Horizon all new sound pack
    Custom The Heavy Cursor pack
    Eurostile, Microgramma and Alexis Fonts
    7 Custom wallpapers
    Event Horizon Extras Includes
    45+ Custom Dock icons
    Objectdock skin
    Event Horizon gadgets
    Custom Event Horizon shellbrd orb
    Custom Event Horizon genuine image for system.cpl
    Custom clock for timedate.cpl
    I would like to thank Mr Grim for all his help with this theme
    thanks much bud could not have done it without you
    [Only registered and activated users can see links. ] , [Only registered and activated users can see links. ]
    7tsp Razorsedge
    System Icon Pack
    ported for Windows 10
    19h1 - 21h2 by
    Moonnique®
    7tsp Razorsedge
    System MUI Side Images
    19h1 - 21h2 by
    Moonnique®
    Additional Extras
    Click on Start Patching.
    💜In Your Heart💜
    25
    4,329
    Information
    changed some gray colors
    and added the full transparent effect
    can be enabled with system transparency
    hope you like it my friends
    Ant1110 is offline
    Oct 2018
    us
    2
    This theme looks awesome! Where can I find the icon pack being used in the screenshots?
    💜In Your Heart💜
    25
    4,329
    Quote Originally Posted by Ant1110 View Post
    hello and this theme has been ported from 10 years old thread
    i dont know if exist thread with Icon Pack for Windows 10
    original Icon Packs v1 and v2 can be found here
    💜In Your Heart💜
    25
    4,329
    sorry i dont remember all of my threads
    Ported Icon Pack can be found here with MUI side Images
    hope this help to you
    💜In Your Heart💜
    25
    4,329
    Information
    ok Friends
    thread has been complete updated
    added Complete Icon Pack for Windows 10 19h1 - 21h2
    MUI Side Images for Windows 10 19h1 - 21h2
    and all Icon Pack Additional Extras
  1. Event Horizon Desaturated Ultimate for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: 06-15-2021, 10:33 PM
  2. Klingon theme for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: 06-13-2021, 09:36 PM
  3. Hardwired Ryzen Blue for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: 06-12-2021, 05:24 PM
  4. Event Horizon theme for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: 06-08-2021, 06:03 PM
  5. The Colony theme for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: 06-03-2021, 05:04 AM
