Thread: TC4Shell
June 30th, 2021 09:55 PM #1
- Aug 2014
- Coolidge, AZ, USA
- 1,919
- 2 Post(s)
- 61 Thread(s)
TC4Shell
TC4Shell
TC4Shell is the perfect tool for opening an enormous range of archive types
such as ZIP, RAR and 7Z, directly in Windows Explorer
Got tired of keeping multiple applications for 7-ZIP, RAR and ISO on your PC? Want to open all archive formats directly in Windows Explorer? Or feeling uncomfortable without your favorite WCX plug-ins for Total Commander? If yes, then TC4Shell will fit just fine!
TC4Shell is a file archiver which makes things as simple as possible, but not simpler. Thanks to its core feature – ultimate integration with Windows Explorer – you will be able to handle archives and disk images just like regular folders. Everything you might need when dealing with archives is now right within reach: copy/paste, drag&drop, running executables directly from archives, as well as working with nested archives and self-extracting (SFX) packages.
In addition, TC4Shell enables you with easy, yet convenient, password manager and package profiles.
If you often send or receive password-protected archives, you can set up passwords for encryption and then simply pick them up from the TC4Shell's dialog box when packing files. The same mechanism also applies to package profiles – simply configure compression parameters, such as compression level and method, and then re-use them by picking up the corresponding profile.
Cheap and cheerful! And finally, if you want to extend TC4Shell functionality, feel free to download and install your favorite archive plug-ins for Total Commander.
Or, if you ever chance upon 7-ZIP archives created with a different codec (such as ZStandard or LZHAM), this codec can be downloaded and used in TC4Shell as well. By default, TC4Shell supports a broad range of archive formats and disk images:
File Types Extensions Decompression Compression 7Z archive 7z, 7zip Yes Yes ZIP Archive zip, zipx Yes Yes RAR Archive rar Yes Yes CAB Archive cab Yes Yes SQX Archive sqx Yes Yes TAR Archive tar Yes Yes GZIP Archive gz, gzip, tgz Yes Yes BZIP2 Archive bz2, bzip2, bz2, tb2, tbz, tbz2 Yes Yes ISO Disc Image iso, udf Yes Yes WIM Disc Image wim Yes Yes
and many others.
TC4Shell works on all operating systems from Windows XP to Windows 10. Both 32-bit and 64-bit versions of Windows are fully supported.
Features
- Deep Integration with Windows Explorer
Thanks to the flexible technology called Namespace Shell Extension, TC4Shell deeply integrates with Windows Explorer allowing you to handle archives and disk images just as regular folders – including all the copy&paste and drag&drop operations.
- Multitude of Supported Formats of Archives and Disk Images
TC4Shell allows you to use Windows Explorer for opening all formats of archives and disk images that you might ever come across – from popular 7-ZIP, ZIP, RAR, ISO and WIM up to the legacy ones.
- Viewing Files Directly in Windows Explorer
TC4Shell can display the contents of each archive directly in Windows Explorer. No need to get accustomed to any new user interfaces – simply use the convenient and familiar Windows Explorer for both folders and archives.
- Opening Files and Running Executables Directly from Archives
TC4Shell allows you to open files within an archive even without extracting them. When you double-click a file, TC4Shell will copy it to a temporary folder, launch the associated application, and then remove all temporary files once they are of no use anymore.
- Opening Nested Archives
Using TC4Shell, you can open and modify nested archives just like regular archives on your hard drive.
- Creating New Archives and Modifying the Existing Ones
The combination of TC4Shell and Windows Explorer allows you to create new archives compressed in 7-ZIP, ZIP, TAR and plenty of other formats. If you have WinRAR installed on your PC, TC4Shell will also be able to create and modify RAR archives.
- Compression Presets and Packing Profiles
TC4Shell allows you to create Compression presets and Packing profiles, and save them for later use. If you do that, you will be able to set the necessary parameters in one click.
- Advanced File List Filtering Based on .zipignore Rules
TC4Shell provides powerful file selection features, so you can quickly and easily select files for packing. You can use black or white lists of file extensions. In case you need more flexibility, TC4Shell also supports advanced file filtering based on rules contained in .zipignore files (which use the same syntax as the popular .gitignore files).
- Creating tar.gz and tar.lz Archives in One Click
In TC4Shell, it is also possible to create tar.gz and tar.lz archives which are very popular on Linux. It is as easy as creating a new archive of any other format.
- Convenient Password Manager
TC4Shell features its own password manager to store frequently used passwords. You can either pick them up manually from the drop-down list each time you open a password-protected archive or instruct TC4Shell to apply them automatically.
- Support of WCX Plug-ins for Total Commander
When the standard TC4Shell functionality is not enough, feel free to download and install your favorite archive plug-ins for Total Commander. Independent developers offer lots of really great WCX plug-ins for free that you can use not only in Total Commander, but also in TC4Shell.
- Support of Codecs for 7-ZIP File Manager
TC4Shell fully supports all codecs for 7-ZIP File Manager (such as ZStandard or LZHAM) and thus can easily unpack archives compressed using any of them.
Lightstar Can Be Very Protective Of His Creations As He Sends A Percentage Of Funds Made To Charities For The Poor, Best To Take This To PMs. As Its Premium, You Could Say "Inspired By" Or Something...
Theme request
