Results 37 to 42 of 42
July 4th, 2021 04:50 PM #1
- 5,516
UltraUXTheme patcher Support for Windows 11
UltraUXThemePatcher v4.3.1
Support for Windows 11 Insider Releases
Support for next major Windows 10 Update 21H2
Solved takeowner bug
Update 11/20/2021 Manuel has updated the UltraUXThemePatcher to version 4.3.0
As in the previous version, Windows 11 and Windows 10 21H2 themes are supported.
Certainly improvements have been made here.
See back to version 4.3.1. In this version, a takeover error (location of a file) was added. Everything else is identical.
[Original 5.07.2021]: "Back to the roots" again. Manuel has updated his UltraUXThemePatcher to version 4.2.0
and thus made it fit for Windows 11 and the upcoming Windows 10 21H2 in order to be able to use external themes.
Of course, I was interested in whether the old Windows 10 themes still work. And you can answer that with yes and no.
Because Microsoft has revised the upper area of the File Explorer and also the new context menu, the dark Windows standard color is displayed here.
I have a natural interest in making the Windows 10 theme work again. And that can be done with their words.
As a result, Microsoft's top-of-the-line File Explorer and even the new context menu has improved its dark Windows standard colors.
You could still help with the context menu by deactivating the new context menu.
In the upper area in the File Explorer and also in the new context menu, the theme developers will have to make corrections
But otherwise it works without any problems. But you should wait until Microsoft provides some updates for Windows 11.
Because until October for the public rollout, a lot can still happen.
These problems will not exist with the upcoming Windows 10 21H2.
The themes for the 2004, 20H2 and 21H1 will continue to work.
Because Microsoft will only make the changes in Windows 11
Windows 11 tested Moonnique®
now you can run and test Secure
all of your first themes for Windows 11
hope this help to you my Friends
Windows 11 Codename Nickel
Windows 11 21H2 OS Build 22449
Windows 11 Codename Cobalt
Windows 11 21H2 OS Build 22000
Manuel Hoefs Changes 2021-11-20
UltraUXThemePatcher version 4.3.1
Support for Windows 10
Support for Windows 7 , 8 , 8.1 and w10 TH2-RS5
Windows XP, 2003, Vista, 2008, 7, 8 Windows 8.1
