Page 1 of 7 12345 ... LastLast
Results 1 to 6 of 42
Thread: UltraUXTheme patcher Support for Windows 11
    ミறѳѳղղįզվદ彡 is offline
    Co-Admin♀ Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young
    🌸In the Future🌸
    5,516
    Virussafe UltraUXTheme patcher Support for Windows 11
    UltraUXThemePatcher v4.3.1
    Support for Windows 11 Insider Releases
    Support for next major Windows 10 Update 21H2
    Solved takeowner bug
    Update 11/20/2021 Manuel has updated the UltraUXThemePatcher to version 4.3.0
    As in the previous version, Windows 11 and Windows 10 21H2 themes are supported.
    Certainly improvements have been made here.
    See back to version 4.3.1. In this version, a takeover error (location of a file) was added. Everything else is identical.
    [Original 5.07.2021]: "Back to the roots" again. Manuel has updated his UltraUXThemePatcher to version 4.2.0
    and thus made it fit for Windows 11 and the upcoming Windows 10 21H2 in order to be able to use external themes.
    Of course, I was interested in whether the old Windows 10 themes still work. And you can answer that with yes and no.
    Because Microsoft has revised the upper area of the File Explorer and also the new context menu, the dark Windows standard color is displayed here.
    I have a natural interest in making the Windows 10 theme work again. And that can be done with their words.
    As a result, Microsoft's top-of-the-line File Explorer and even the new context menu has improved its dark Windows standard colors.
    You could still help with the context menu by deactivating the new context menu.
    In the upper area in the File Explorer and also in the new context menu, the theme developers will have to make corrections
    But otherwise it works without any problems. But you should wait until Microsoft provides some updates for Windows 11.
    Because until October for the public rollout, a lot can still happen.
    T
    hese problems will not exist with the upcoming Windows 10 21H2.
    The themes for the 2004, 20H2 and 21H1 will continue to work.
    Because Microsoft will only make the changes in Windows 11
    Operating System Support*
    Windows 11 tested Moonnique®
    now you can run and test Secure
    all of your first themes for Windows 11
    hope this help to you my Friends
    Windows 11 Codename Nickel
    Windows 11 21H2 OS Build 22449
    Windows 11 Codename Cobalt
    Windows 11 21H2 OS Build 22000
    Manuel Hoefs Changes 2021-11-20
    UltraUXThemePatcher version 4.3.1
    Support for Windows 10
    Windows 10 21H2 2009 OS Build 19044
    Windows 10 21H1 2009 OS Build 19043
    Windows 10 20H2 2009 OS Build 19042
    Windows 10 20H1 2004 OS Build 19041
    Windows 10 19H2 1909 OS Build 18363
    Windows 10 19H1 1903 OS Build 18362
    Support for Windows 7 , 8 , 8.1 and w10 TH2-RS5
    Supported for 32 Bit-System and 64 Bit-System
    Windows XP, 2003, Vista, 2008, 7, 8 Windows 8.1
    About UltraUXThemePatcher
    Changes 4.3.1 (2021-11-20)
    Support for Windows 10 next Major update 21H2
    Problems after big Update should be fixed
    UltraUXThemePatcher modifies your system files so that 3. party themes can be used.
    You can download Windows themes from third parties and activate them.
    The program backups the original system files and all changes can be undone by uninstalling if you have issues.
    UltraUXThemePatcher is available for Windows XP to Windows 10 (up to April Update 2004) for 32bit and 64bit version
    Windows 11 Enterprise Edition 22449
    Codename Nickel
    Windows 11 Enterprise Edition 22000
    Codename Cobalt
    https://mhoefs.eu/software_uxtheme.php?lang=en
    Forum
    https://www.winfuture-forum.de/index.php?showtopic=135305
    UltraUXThemePatcher
    help for Manuel Hoefs MZottel and others on WinFuture
    4K 5K 8K monitors need using Supported themes with DPI scaling up to 100% - 200%
    Secure Scaling for this themes is 100% - 200%
    without break down your system and black screen after next reboot
    All Supported themes can be downloaded here
    https://virtualcustoms.net/forumdisplay.php/1293-Moonnique-s-Ported-Themes
    Thank you for the update MZottel
    FAQ has been updated and link has been added to (e.g.)
    Problem - After patching on Windows 10 and login into, the PC get black screen and reboots
    I have a 4k monitor installed and run in black screen and reboot issue. How do I fix it?
    A 4k monitor or higher uses a special resolution, therefor themes are necessary that support 200% DPI (e.g. here)!
    zbigniew59 is offline
    Skilled
    Nov 2013
    sveden
    105
    How to use StartISBack ++ because it doesn't work on windows 11?
    Master_x_3 is offline
    Jul 2021
    Space
    1
    Great work! However, the updated patcher disables animations for all windows 11 windows, makes the system too laggy! the windows 11 release that you built the patcher upon doesn't seem to be the latest from microsoft "latest is 22000.51" idk if that's why the system becomes so laggy after patching.
    🌸In the Future🌸
    5,516
    Quote Originally Posted by zbigniew59 View Post
    you need to wait for the updated version of StartIsBack++ for Windows 11 this fix your start menu and taskbar
    we can fix some of the other locations for WSB after final release because this is the Insider preview co release
    🌸In the Future🌸
    5,516
    Quote Originally Posted by Master_x_3 View Post
    sorry but UltraUXTheme patcher do not have any effect on animations
    this just remove digital signature from all 3rd party themes
    if you have some problems with animations you can try this alternative SecureUXTheme patcher available here
    https://virtualcustoms.net/showthread.php/86740-SecureUxTheme-patcher-Support-for-Windows-11
    remember this is only the Insider preview co release for testers with many bugs this is not the final release
    jejemc is offline
    Oct 2012
    france
    54
    7 Thread(s)
    hello Moonique I have patched the system, but the themes do not appear in the theme section? What for ? <resolved
    I installed the msi theme but everything and not change the taskbar the window outline remains unchanged do you know where it comes from? thank you
  1. Best Theme Patcher For Windows 10
    By Foad in forum General Questions
    Last Post: December 5th, 2023, 03:41 PM
  2. Explorer Patcher for Windows 11
    By ミறѳѳղղįզվદ彡 in forum General Windows 11 Customization
    Last Post: December 12th, 2021, 03:09 PM
  3. SecureUxTheme patcher Support for Windows 11
    Last Post: November 29th, 2021, 10:52 PM
  4. Windows 16273 Theme Patcher?
    By Nilukio in forum General Windows 10 Customization
    Last Post: August 25th, 2017, 01:47 PM
  5. UxStyle Patcher Windows 8.1
    By Dark Knight in forum Windows 8 & 8.1 Theme Help & Support
    Last Post: January 25th, 2014, 09:36 PM
