Page 1 of 2 12 LastLast
Results 1 to 6 of 11
Thread: ThisIsWin11 + Restore Windows 10 File Explorer Share
    றѳѳղղįqվદ® is offline
    💜진정한 지식은💜💜결코 죽지 않는다💜
    💜In Your Heart💜
    25
    4,350
    Star ThisIsWin11 + Restore Windows 10 File Explorer
    ThisIsWin11
    A customer asked me to quickly present Windows 11.
    So i threw some of the news from
    theverge, windowscentral and others into an form and added a magic - feature demonstration - button.
    Now you can navigate your way through a short Windows 11 tour using this magic button, which only works under Windows 11.
    You can of course also use the app and click through under Windows 10, but with a little less fun.An internet connection is required to use the app.
    For the future i plan to open the possibility to configure Windows 11 in the wizard as well.
    Basic things like background image, privacy etc, provide tweaks to get better started e.g.
    how to get classic context menu of file explorer back and community optimizations.
    Guides you step by step in getting to know and setting up Windows 11
    Customize Windows 11 to your needs
    Refactored Tweaker code
    (runs as an "independent" instance and can also be opened via Settings > Open Tweaker menu)
    Numerous other code improvements
    (modular structure of some pages, i.e. Info, Tweaker etc.)
    UI Improvements
    VirtualCustoms88 is offline
    Sep 2017
    Philippines
    2
    those reg hacks no longer works on later builds.
    the only one that works for now is this:
    HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Shell\Update\Packages" /v "UndockingDisabled" /t REG_DWORD /d "00000001"
    im really hoping someone can modify the taskbar to allow drag and drop and other things.
    💜In Your Heart💜
    25
    4,350
    Thread has been updated
    ThisIsWin11 version 0.31.0
    Patched Apps/debloater module with better apps detection and status report
    some async functions and possibility to hide system apps
    import own bloatware lists (try importing "bloatwareapps-11.txt" located in data folder) and several other UI fixes.
    Refactored data storing (now everything app related is stored in root "data" folder of ThisIsWin11
    (old "custom" folder is no longer necessary and can be removed)
    Changed default font in Preview window to Consolas (it was previously Cascadia Code which is per default available on Win11
    but Consolas is just my favorite monospaced font)
    Added Windows 11 debloater/apps uninstaller module (you'll find it in the Apps page or Settings menu > Open Debloater page)
    Numerous improvements in code and UI
    Enhanced Custom/Tweak module (added functions to Open in new window, Cancel a running script, Import, Edit and Show applied tweaks)
    Refactored Showcase of Win11 features
    Improved scripting engine and several tweaks
    Numerous other fixes in code and UI
    Refactored Tweak module (runs as an "independent" form and can also be opened via Settings > Open Tweaker menu)
    Improved stability of Tweak module
    Added several new tweaks/scripts
    💜In Your Heart💜
    25
    4,350
    ThisIsWin11 version 0.35.0
    Added Package Manager module built on Winget
    (you can import your own package lists and export them to powershell)
    Fixed some critical DPI, resizing an anchoring issues within new module instances
    (the UI is so far polished and reaches stable status)
    Added new privacy tweak to disable unnecessary Windows 11 services
    Code refactoring
    💜In Your Heart💜
    25
    4,350
    ThisIsWin11 version 0.50.0
    Added Privacy analysis and issues fixer module (you could call it the optimized successor for [Only registered and activated users can see links. ] but on Win11)
    Each app module gets a little more originality and gets an internal app name and versioning scheme.
    - Privacy module runs under "Lucent11"
    - Debloat module is named "Bloatbox" (we all know the
    [Only registered and activated users can see links. ] but now a refactored version for Win11)
    - Tweaker module is named "PimpApp". I can't help it, i know.
    [Only registered and activated users can see links. ]. Do not take it seriously. A bit of fun is essential! ��
    - Nothing changes for the Package Manager as it is partly based on winget and the development effort for me is rather low
    Improved overall stability
    Several fixes in UI and code
    💜In Your Heart💜
    25
    4,350
    ThisIsWin11 version 0.60.0
    ThisIsWin11 is out of preview status.
    All provided modules work stable under the current Windows 11 build.
    There will certainly be some more changes, but for now we have reached stable status.
    Version 1.0 will be ready by the time Windows 11 is released.
    Redesigned UI completely and added more Windows 11 design elements.
    The UI is softer and decluttered
    Code refactoring
    The following 4 Modules are ready
    1. Lucent11 for checking and optimizing Windows 11 privacy
    (all changes made can also be undone)
    2. Kickassbloat for removing pre-installed Windows 11 apps
    3. Packages for installing quickly apps
    4. PowerClicks for automating several Windows 11 tasks
  1. In dark mode, how to make Windows File Explorer use a title bar different from other
    By Shompinice in forum General Windows 10 Customization
    Last Post: 06-20-2020, 07:02 AM
  2. Alternative file explorer for windows 10?
    By Lassar in forum General Windows 10 Customization
    Last Post: 02-07-2017, 08:08 PM
  3. extract file/files from restore disc
    By AlphaOmega in forum General Discussion
    Last Post: 12-23-2015, 03:51 AM
  4. Fix: Windows Explorer, File and Folder Problems automaticall
    Last Post: 12-11-2010, 12:19 AM
