Thread: CaseLabs Ultimate edition for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    ミறѳѳղղįզվદ彡 is offline
    Co-Admin♀ Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young
    🌸In the Future🌸
    5,516
    Package Favorite CaseLabs Ultimate edition for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Harvey Sewdin
    Windows 10 21H2 2009 OS Build 19044
    Windows 10 21H1 2009 OS Build 19043
    Windows 10 20H2 2009 OS Build 19042
    Windows 10 20H1 2004 OS Build 19041
    Windows 10 19H2 1909 OS Build 18363
    Windows 10 19H1 1903 OS Build 18362
    7tsp Windows 10 Dark Edition Icon Pack for Windows 10
    ported for Windows 10 19h1 - 21h2 by
    Moonnique®
    7tsp Icon Pack for Windows 10 19h1 - 21h2
    Please do not run this Icon Pack on w7 w8 w10 TH2-RS5!
    This Icon Pack has been created only for Windows 10
    with new .mun files located in the
    C:\Windows\SystemResources directory
    Icon Pack has been ResRebuilded
    I have noticed 7tsp packs have been getting bigger and bigger in size.
    This is because some res editors leave old data inside the res files after modifying and saving them.
    This tool rebuilds all res files from a resources folder so they are clean of any rest data
    3D Objects Folder Icon and OneDrive Folder Icon
    OneDrive Quick Access Folder Icon
    OneDrive.exe - .exe file location
    c/Users/*your username*/AppData/Local/Microsoft/OneDrive/OneDrive.exe
    Rename original OneDrive.exe file as OneDriveOld.exe and copy my new OneDrive.exe file
    Open up 7TSP & click Add a Custom Pack & select the icon pack you want to install.
    Click on Start Patching.
    By default 7TSP will create a restore point & install the icon pack.
    Once installation is done reboot & you're done
    Install Fonts included in the "Extras" folder Apply
    System Metrics included in the "Extras" folder and logout or reboot Install an
    iPack of your choice to change the system icons (check the Theme Extras section above for a link to the icons in the preview)! Select the
    Theme's Start Menu and Taskbar in the StartIsBack++ configuration. If it's not a visible option to select the theme's start menu, apply your custom theme first! Copy a
  1. HUD Machine Red Ultimate edition for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    By ミறѳѳղղįզվદ彡 in forum Themes by Mr GRiM
    Last Post: April 4th, 2023, 03:52 PM
  2. JARVIS Ultimate edition for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    By ミறѳѳղղįզվદ彡 in forum Moonnique's Ported Themes
    Last Post: December 7th, 2022, 09:14 AM
  3. Zero-G Dark and Light Ultimate edition for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: February 8th, 2022, 12:04 AM
  4. Blade v2 Ultimate edition for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: July 30th, 2021, 02:41 PM
  5. M-CLASS Ultimate edition for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: July 11th, 2021, 09:25 AM
