Page 1 of 2 12 LastLast
Results 1 to 6 of 10
Thread: Toxic Blue for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2 Share
    றѳѳղղįqվદ« is offline
    💜진정한 지식은💜💜결코 죽지 않는다💜
    💜In Your Heart💜
    25
    4,447
    Package Favorite Toxic Blue for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Toxic Blue theme for Windows 10
    7tsp Blade v2 Icon Pack for Windows 10
    ported for Windows 10 19h1 - 21h2 by
    Moonnique«
    7tsp Icon Pack for Windows 10 19h1 - 21h2
    This Icon Pack has been created only for Windows 10
    with new .mun files located in the
    C:\Windows\SystemResources directory
    Click on Start Patching.
    [Only registered and activated users can see links. ]System Metrics included in the "Extras" folder and logout or reboot Install an
    [Only registered and activated users can see links. ]iPack of your choice to change the system icons (check the Theme Extras section above for a link to the icons in the preview)! Select the
    [Only registered and activated users can see links. ]Theme's Start Menu and Taskbar in the StartIsBack++ configuration. If it's not a visible option to select the theme's start menu, apply your custom theme first! Copy a
    [Only registered and activated users can see links. ]Start Orb from the "Theme" folder to a new location, rename it, then open the StartIsBack++ configuration, click Add... select the Start Orb and click Apply.
    Athoss is offline
    Jan 2021
    Jerusalem
    2
    Thanks for the gift!
    💜In Your Heart💜
    25
    4,447
    Quote Originally Posted by Athoss View Post
    lahercoll is offline
    The Golden Dragon
    Nov 2009
    japan
    1,323
    8 Post(s)
    259 Thread(s)
    thanks friend a great job
    a big hug
    poorya is offline
    Oct 2015
    iran
    2
    Here is Toxic Blue icon pack
    💜In Your Heart💜
    25
    4,447
    Quote Originally Posted by poorya View Post
    hello and your link has been deleted
    in the future please do not upload here any files and links from the other fake sites where is shared all of our original works from our VC site
  1. Event Horizon Blue Ultimate edition for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    By றѳѳղղįqվદ« in forum Moonnique's Ported Themes
    Last Post: 06-15-2021, 09:39 PM
  2. Annihilation theme for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: 06-14-2021, 09:12 AM
  3. Klingon theme for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: 06-13-2021, 09:36 PM
  4. Special Edition for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: 06-12-2021, 08:35 PM
  5. Hardwired Ryzen Blue for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: 06-12-2021, 05:24 PM
