August 17th, 2021 01:13 PM #1
- 5,516
How to Customize StartIsBack , Icons , Start Orbs , default User pic frame .etc
StartIsBack++
how to change the default Start Menu user pic frame .etc
how to change StartIsBack Icon
go to C:\Users\*your username*\AppData\Local\StartIsBack
or go to C:\program files\StartIsBack
and open StartIsBackCfg with Restorator or with resource hacker
Default StartIsBack Icon you can find as
StartIsBackCfg\Icon\MAINICON
how to change StartIsBack Blur and Clear Icons
Default StartIsBack Blur and Clear Icons you can find as
StartIsBackCfg\Icon\ZBLURMORE
StartIsBackCfg\Icon\ZBLURMOST
StartIsBackCfg\Icon\ZBLUROFF
StartIsBackCfg\Icon\ZBLURON
how to change , add or remove StartIsBack Start Orbs
exist more way how to
open StartIsBackCfg\Appearance and click on +
add your Start Orb supported images is PNG and bmp
how to change , add or remove StartIsBack Start Orbs manually
go to C:\Users\*your username*\AppData\Local\StartIsBack\Orbs
or go to C:\program files\StartIsBack\Orbs
copy or remove Start Orbs from this directory
how to replace StartIsBack Start Orbs permanently
open file Windows 7.orb with Restorator or with resource hacker
Default StartIsBack Start Orbs you can find as
Windows 7.orb\Bitmap\6805
Windows 7.orb\Bitmap\6806
Windows 7.orb\Bitmap\6807
Windows 7.orb\Bitmap\6808
how to replace Start Orb permanently in the theme .msstyle file
open your theme .msstyle with Restorator
and replace default Start Orb
.msstyle file\IMAGE\956
if someone do not have Restorator then can replace default Start Orb with Windows Style Builder here
Taskbar & System Tray > TaskBar > Aero > Start Button > Small Icons Start Button
Taskbar & System Tray > TaskBar > Aero > Start Button > Small Icons Start Button > Normal
Taskbar & System Tray > TaskBar > Aero > Start Button > Small Icons Start Button > Hot
Taskbar & System Tray > TaskBar > Aero > Start Button > Small Icons Start Button > Pressed
Taskbar & System Tray > TaskBar > Aero > Start Button > Large Icons Start Button
Taskbar & System Tray > TaskBar > Aero > Start Button > Large Icons Start Button > Normal
Taskbar & System Tray > TaskBar > Aero > Start Button > Large Icons Start Button > Hot
Taskbar & System Tray > TaskBar > Aero > Start Button > Large Icons Start Button > Pressed
how to replace StartIsBack Start Menu user pic frame permanently
and create here new SubFolder = Bitmap
.msstyle file\Bitmap\7013
How to Customize StartAllBack++ , Icons , Start Orbs , Details Pane .etc
By ミறѳѳղղįզվદ彡 in forum General Windows 11 CustomizationReplies: 16Last Post: June 23rd, 2024, 05:24 PM -
Picture Frame Logon and User Frame
By IcicleThief69 in forum Log On ScreensReplies: 3Last Post: August 27th, 2013, 06:24 PM -
User Frame
By Psych0t1c in forum Windows 7 Theme Help & SupportReplies: 2Last Post: December 18th, 2009, 04:37 PM
The Settings app is not affected by .msstyles.
How do i change these...
