October 2nd, 2021 04:38 PM #1
- 5,510
How to change Taskbar size on Windows 11
Pureinfotech
Make Taskbar smaller or bigger
Yes, you can change the taskbar size on Windows 11
but you need to edit the Registry – here's how.
Windows 11 introduces an updated version of the Taskbar with a new design that aligns all items to the center of the screen
and it includes new buttons for the Start menu, Search, Task View, and Widgets.
Although the Taskbar has a similar design to the one available on Windows 10
the new version (currently) lacks some essential features, including the ability to change the Taskbar size.
However, it’s been discovered (via @thebookisclosed) that it’s possible to modify the Registry to change the size to small, medium, or large.
If you are among those users who like the classic Start menu
you can also bring it back on Windows 11 by editing the Registry with these instructions.
In this guide, you will learn the steps to make the Taskbar larger or smaller on Windows 11.
Warning: It’s very important to note that modifying the Windows Registry can cause serious problems if not used properly.
It’s assumed you know what you’re doing and that you have created a full backup of your system before proceeding.
Change Taskbar size on Windows 11
To change the Taskbar size on Windows 11, use these steps:
1. Open Start on Windows 11.
2. Search for regedit and click the top result to open the app.
3. Browse the following path:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
Right-click the Advanced key, select New, and click on DWORD (32-bit) Value.
5. Name the key TaskbarSi and press Enter.
6. Double-click the newly created DWORD and change its value from 0 to 2 to change the Taskbar icons size to large.
The value 0 is for the small size and 1 is for the default icon size.
7. Click the OK button.
8. Restart the computer.
Once you complete the steps, the Taskbar will reflect the size you specified on Windows 11.
If you want to revert the changes, you can always follow the same instructions, but on step No. 4
right-click the TaskbarSi DWORD and select the Delete button.
How to change the height of the windows 10 taskbar?
By nisa in forum General Windows 10 CustomizationReplies: 5Last Post: May 23rd, 2021, 02:33 AM -
Taskbar size/transparenzy
By XXXxxxXXX in forum Taskbar & System TrayReplies: 4Last Post: January 4th, 2012, 06:16 PM -
Fix: Windows 7 taskbar is 3 times wider, after you change it
By razorsedge in forum News & ReviewsReplies: 0Last Post: October 17th, 2010, 10:35 PM -
Change the size of Windows 7 Taskbar Thumbnails
By Twisted-Devil in forum Windows 7 Theme Help & SupportReplies: 1Last Post: March 7th, 2010, 08:25 AM
Custom Class Maps and...
