Results 7 to 12 of 15
Thread: How to Customize StartAllBack++ , Icons , Start Orbs , Details Pane .etc
    ミறѳѳղղįզվદ彡 is offline
    🌸In the Future🌸
    5,510
    Virussafe How to Customize StartAllBack++ , Icons , Start Orbs , Details Pane .etc
    StartAllBack++ for Windows 11 21h2++
    how to move Details Pane on Top (TopShell)
    how to move Details Pane on Bottom (BottomShell)
    https://virtualcustoms.net/OldNewExplorer-TopShell-and-BottomShell-Right-and-Left-side-8-versions-for-Windows-11
    StartAllBack use this new changes ported and included from OldNewExplorer
    if you like some of this changes then can be all edited manually in the
    StartAllBack64.cfg UIFILE DETAILS
    UIFILE 3, 4, 5, 6, 19, 20, 21
    and in the
    StartAllBackA64.cfg UIFILE DETAILS
    how to change StartAllBack Icon
    go to C:\Users\*your username*\AppData\Local\StartAllBack
    or go to C:\program files\StartAllBack
    and open StartAllBackCfg with Restorator or with resource hacker
    Default StartAllBack Icon you can find as
    StartAllBackCfg\Icon\MAINICON
    how to change StartAllBack Blur and Clear Icons
    Default StartAllBack Blur and Clear Icons you can find as
    StartAllBackCfg\Icon\ZBLURMORE
    StartAllBackCfg\Icon\ZBLURMOST
    StartAllBackCfg\Icon\ZBLUROFF
    StartAllBackCfg\Icon\ZBLURON
    ​how to change , add or remove StartAllBack Start Orbs
    exist more way how to
    open StartAllBackCfg\Taskbar and click on +
    add your Start Orb supported images is PNG and bmp
    how to change , add or remove StartAllBack Start Orbs manually
    go to C:\Users\*your username*\AppData\Local\StartAllBack\Orbs
    or go to C:\program files\StartAllBack\Orbs
    copy or remove Start Orbs from this directory
    how to replace StartAllBack Start Orbs permanently
    open file Windows 7.orb with Restorator or with resource hacker
    Default StartAllBack Start Orbs you can find as
    Windows 7.orb\Bitmap\6805
    Windows 7.orb\Bitmap\6806
    Windows 7.orb\Bitmap\6807
    Windows 7.orb\Bitmap\6808
    how to replace Start Orb permanently in the theme .msstyle file
    open your theme .msstyle with Restorator
    and replace default Start Orb
    .msstyle file\IMAGE\956
    if someone do not have Restorator
    then can replace default Start Orb with Windows Style Builder here
    Taskbar & System Tray > TaskBar > Aero > Start Button > Small Icons Start Button
    Taskbar & System Tray > TaskBar > Aero > Start Button > Small Icons Start Button > Normal
    Taskbar & System Tray > TaskBar > Aero > Start Button > Small Icons Start Button > Hot
    Taskbar & System Tray > TaskBar > Aero > Start Button > Small Icons Start Button > Pressed
    Taskbar & System Tray > TaskBar > Aero > Start Button > Large Icons Start Button
    Taskbar & System Tray > TaskBar > Aero > Start Button > Large Icons Start Button > Normal
    Taskbar & System Tray > TaskBar > Aero > Start Button > Large Icons Start Button > Hot
    Taskbar & System Tray > TaskBar > Aero > Start Button > Large Icons Start Button > Pressed
    hope this help to you my Friends
  1. How to Customize StartIsBack , Icons , Start Orbs , default User pic frame .etc
    Last Post: September 25th, 2021, 01:54 PM
  2. Shell32 Details Pane Mod for Windows 8.1 Only!!
    By Mr GRiM in forum Customization Tools
    Last Post: September 25th, 2019, 01:23 AM
  3. How to move the details pane at the top in Windows Explorer ?
    By ceo54 in forum Windows 8 & 8.1 Theme Help & Support
    Last Post: September 3rd, 2019, 06:42 AM
  4. How Do I Hide Details Pane at Bottom of Win Explorer??
    By koolx in forum Windows 10 Theme Help and Support
    Last Post: May 20th, 2018, 10:30 AM
  5. Bottom Details Pane for Windows 8
    Last Post: July 20th, 2013, 08:55 AM
